finned aluminum valve covers
Discussion in 'The Hokey Ass Message Board' started by k.c., Oct 28, 2009.
  1. k.c.
    k.c.
    How do you keep/get the paint off the top of the fins?
  2. Von Rigg Fink
    Von Rigg Fink
    from Garage
    wipe it off with a rag and some mineral spirits while the paint is still tacky
    or a small block of wood with some fine sand paper after it has cured real good..
  3. Spray, then wipe the fins clean while the paint is still damp.
  4. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    You could use chapstick and roll it on the top of the fins. I have not had much luck but other have with that method. I put blue tape on and used a razor blade to trim the excess off. My valve covers came out great I think!
  5. 49ratfink
    49ratfink
    I use a DA sander. if I wanted more than a brushed finish I'd use a block with sandpaper.
  6. 2afbs
    2afbs
    Get 1/4" masking tape then trim it with an exacto knife or razor blade, iv'e been working on 2 this afternoon. Trying to remove after painting i always slop some solvent on the painted areas i don't want to remove and screw that up.
  7. k.c.
    k.c.
    Thanks guys! I should be able to work somethin out with all those suggestions.
  8. 5window
    5window
    I used 3/4" blue masking tape so I could cover several fin tops at once, then trimmed the tape down with a #11 (pointed) scalpel blade. Painted the valleys and peeled off the tape.
  9. HotRodFreak
    HotRodFreak
    I sand the fin tops after paint dries.
  10. Richard Head
    Richard Head
    I've used 1/8" 3M fineline tape a couple of times. It was alot easier than trying to remove catalyzed paint afterward.
    Dave
  11. Comet
    Comet
    I tape around the perimeter only, then paint and wipe the fins. I like the look of a smoother transition of the paint (more feathered) than the taping provides, plus it's a lot less work. Just make sure your rag is damp with thinner/mineral spirits or whatever and keep the rag wad smooth and tight like tennis ball.
  12. rusted_nut
    rusted_nut
    from Arkansas
    I polished the fins beforehand and just waited for the paint to completely dry. It chips right off the polished portions with only a fingernail yet still sticks to the roughed up portion.
