Can't make up my mind which direction to go with my roadster. suggestions?
Discussion in 'The Hokey Ass Message Board' started by 90ssp, Oct 29, 2009.
  1. 90ssp
    90ssp
    from dallas, ga
    Just got it a few days ago on trade. The only catch is that it will be on a small budget...
  2. dudley32
    dudley32
    are the cop's already there ???
  3. tfeverfred
    tfeverfred
    Well, to state the obvious, a windshield. I'd go with a different air cleaner. Those foam type have been known to catch fire if your engine backfires. Maybe a chrome scoop type. Maybe different headlights. Either chrome or black Dietz's. Change out the steering wheel. I'd also lose the white letter tires on the rear. Maybe a pair of bomber seats or a simple bench style. Those are small changes I'd make. It seems like a good start for whatever you'd like to do. In many ways, you can't lose, unless you make it... well you know... that "RR" word.
    Oh, not to be picky, but in the pic the exhaust seems kinda low to the ground. Maybe it's just the angle of the pic.
  4. Outlawed Dreams
    Outlawed Dreams
    Velocity stacks, a windsheild, and some pie-crust slicks out back. Other than that its fine the way it is.
  5. Pinstriper40
    Pinstriper40
    Here are a few long-term goals to shoot for.
  6. Pinstriper40
    Pinstriper40
    I'd start by adding a windshield, some lakes-style headers, bias ply tires, and the aforementioned bomber seats or bench seat. Gradually transform the car to what you really want! Enjoy!
  7. 90ssp
    90ssp
    from dallas, ga
    Lol...unfortunately yes but I can't kick myself out...maybe my department will let me put some white walls on it
  8. 90ssp
    90ssp
    from dallas, ga
    I got the original split windshield...Its still in the back of my suburban...Thanks for the ideas guys!!
  9. flynbrian48
    flynbrian48
    Windshield, lose the headers and header muffs dragging in the dirt, wheels and tires for starters.
  10. fitzee
    fitzee
    Make a driver out of it then change things as you go.I would go right through that car and make it safe. cool little project to start with.
    Pinstriper40,them 27`s are sweet
  11. lucky_1974
    lucky_1974
    Get rid of that steering wheel too...the car has potential though.
  12. donnie
    donnie
    from NC
    Short term
    Paint Wheels, headlights and Radiator and radiator supports black
    Put hubcaps on it.
    Change steering wheel
    Get rid of the front bumper thingie.
    Run exhaust under the car, straight pipes all the way out the back.
    Put on windshield.
    Change air cleaner
    After you have enjoyed it a while and fixed what needs to be fixed
    New tires
    Paint
    Change distributor
  13. lockwoodkustoms
    lockwoodkustoms
    You can always trade it to me and I will figure it out........lol. But I would even go as far as to putting a Flathead in it. They just look right at home in those little roadsters.
  14. 'Mo
    'Mo
    I'll play.
    '56 Dodge Royal blue. Cut down deuce grille shell, blue steelies with WWW's and baldy caps. White interior with blue pleats. Rolled rear pan and '49 Pontiac tail lights.
  15. Man, will you be able to bridge the gap between the local rodders and the rest of your department!
  16. Jerry27Tub
    Jerry27Tub
    Looks like the start of a cool project!
    First thing I would do is grab a handful of wrenches and tighten everything that is supposed to be tight and then lube up everything that should be loose. Grab a flashlight and look close underneath at any welds, look for stress cracks and anything that looks shoddy. Look for missing fasteners - nuts, lock washers, cotter pins. Check it system by system. Check the fuel lines, brake lines, exhaust. Look for leaks, proper clearances. Make sure there are no bare wires, check the grounds and that the battery is properly secured.
    As you are giving it a close inspection, make sure the engineering looks right. Does the suspension or steering bind? Does anything rub?
    Then you can make a list and prioritize what you need to do or fix.
    I would definitely grab some black spray paint and tone down some of the red. Throw on the windshield add some hub caps and enjoy that ****er!
  17. plywude
    plywude
    from manteca ca
    I'd start with a new frame that steering box hanging out in the wind ****s, you can find an model A frame, box it from the front crossmenber back to the trans mount and then switch over what's good on the old frame and **** can the junk, the car has potential you just have to make it safe and drivable..............................:D
  18. 90ssp
    90ssp
    from dallas, ga
    thanks for the suggestions guys...hope to get started soon
  19. Are the Cops after you allready?
    Maybe you should find photo's on what you would like it to be... and start morphing it into shape a little bit at a time!
    No rush... because as soon as you start rushing anything it starts costing "Money".
  20. 90ssp
    90ssp
    from dallas, ga
  21. 90ssp
    90ssp
    from dallas, ga
    i definitely want wide whites. I'm thinking a partial hood and maybe a 33-34 grille slightly slanted. Maybe channel the body a little and find a motor with soul...hemi, nailhead
  22. 63Compact
    63Compact
    Maybe its the beam but I think it needs more Cowbell !!!!!!!
  23. 90ssp
    90ssp
    from dallas, ga
  24. 3wLarry
    3wLarry
    from Owasso, Ok
    From an old Saturday Night Live skit...you don't want to know...
    kidcampbell71 likes this.
  25. Idlzruf
    Idlzruf
    That black and white will make an excellent donor car for a future endevor too.
  26. Irish Dan
    Irish Dan
    Wide whites for sure! Hell, even used WWW's could be bought pretty cheap and would look a hundred times better than what's on it now! Also, I'd run at least 10 inch diameter headlights on it. You've really got a lot of potential sittin' there, and you won't have to spend a fortune making it cool! Just take your time and do what you can within your budget. Good Luck!
  27. 90ssp
    90ssp
    from dallas, ga
    lol...i get it now:)
  28. claymore
    claymore
    If you are going to keep it for awhile try and get it registered at DMV to see if it can be done before dumping a bunch of money in it.
  29. lugnutz9032
    lugnutz9032
    from Palatka,Fl
    Don't put a deuce grill on it.:rolleyes:Jeez,whats wrong with T or A grillshells.Deuce grills are over done.Throw some bias plys on there and go have some fun with it.
  30. 90ssp
    90ssp
    from dallas, ga
    True true...not to mention the price of those grilles which will probably but them out of my budget range anyway
