Moon tank...remove the dents or leave the dents
Discussion in 'The Hokey Ass Message Board' started by hb32, Oct 29, 2009.
  1. After several years of gathering, managed to get all the right pieces. Tank is an original, not a repop but it has several dents and my Deuce is not high tech but not a rat rod either. Leave the dents or get them worked out and is that an option?
  2. hotrod-Linkin
    hotrod-Linkin
    they show character...leave em.
  3. DRUGASM
    DRUGASM
    hmm...thats a good question. They dont really take anything away from the tank...by that I mean they arent big enough to affect the way it was designed to operate. I think I would leave them for now....looks like it would be easy enough to pull apart later and fix if it really bothers you.
  4. Pinstriper40
    Pinstriper40
    Leave 'em. Mine's all dented up and stuff too- but it's old. If you want a perfect one buy a new one or spent the real big bu**x and get a pristine vintage example. It doesn't sound like you want to do either, so leave it. I wouldn't knock you for it.
  5. cowboy.3d
    cowboy.3d
    from Austin TX
    Hit it again! I'll lend you the F'ing "HAMB'er"
  6. i'm not exactly sure how you would get them out...you would have to get them through the gas filler neck. you may just make it worst..i say leave them
  7. Hey_Pauly
    Hey_Pauly
  8. 22dodge
    22dodge
    from Nevada
    I would leave them. Nice piece.
    Gives it some "history" and doesn't hurt the looks... '22
  9. DirtySanchez
    DirtySanchez
    from So Cal
  10. furyus
    furyus
    from Virginia
    Garage Queen perfect, all shiny and new, is nice. Dents are cool. I'll take cool over nice any day.
    furyus
  11. Don't think there is a practical, noninvasive way to fix it. Run it as is.
  12. The37Kid
    The37Kid
    I've got one that isn't as nice for my Lyndwood rail, I plan to buy a new one and add the old filler neck.
  13. panhead_pete
    panhead_pete
    For me it will depend on the build. Mine is worse then yours but will suit my build as my whole car will be a little the same. If you are spending heaps of $ or hrs in body work, putting on really nice gloss paint, flash wheels etc I'd be hunting up a perfect one.
  14. Jerry27Tub
    Jerry27Tub
    If you are building a driver than I say run it. Once you get some rock chips on the grille shell it will look perfect.
  15. lowkroozer
    lowkroozer
    Put down the mouse ,pick up a hammer add a dent and mount it on the car, You know make it your own
  16. gimpyshotrods
    gimpyshotrods
    If you plan on running it up front, and driving on the road, it is going to end up looking up like this anyway. The tank is authentic, and so are the dents. I say leave it alone.
  17. Krash
    Krash
    from Cleveland
    Definitely leave them. Adds character
  18. At the local cruise.........
    'Yeah, and that dent was from when it was on the front of 'Winged Express', but then they went to the 'bullet' so we threw it on the Lakes car. Thats where the other dent came from, then I needed one for this car, so...........'
  19. redlinetoys
    redlinetoys
    from Midwest
    Looks good to me!
  20. Now thats funny :D
  21. dana barlow
    dana barlow
    from Miami Fla.
    I so hate patina paint[fanzy word for screwed up],but thoughs small dings are fine in a alum tank. lev'm:D
  22. Sphynx
    Sphynx
    from Central Fl
    Wow , you got a good answer from all , leave em.
  23. fab32
    fab32
    I took one that was in much worse shape and made it look almost new. I bought a length of 1/4" round rod and made several pry tools that allowed me to access each dent through the fill hole. and slowly work them out from inside the tank. You have to work slowly as stretching the aluminum from the inside is easy. If you've ever watched one of those dent removal guys that use pry bars and work the inside of a dented fender without removing the paint it's the same kind of deal. After you get the dents out then work the whole outaside of the tank with fine emery cloth and a scothbrite pad to restore the brushed finish. It's a lot of patient work and when your done you'll probably wish you'd of left the dents in.:eek::)
    Frank
    kidcampbell71 likes this.
  24. claymore
    claymore
    Fix them.
  25. wvenfield
    wvenfield
    You should add more dents and some dirt so it looks more like you just found it somewhere. Like in an old barn or something.
  26. andysdeuce
    andysdeuce
    I have one just like it that I bought on the hamb board a couple years ago.
    I'm gonna put it on my sixties styled "A" roadster.
    Leave the small dents and dings...it adds character and shows the rod to be a driver. Not a trailer...garage queen. The cool factor is there with a few dings in my opinion. (Don't listen to Frank) he's just a GOLDCHAINER at heart!!!!:p:D:D
  27. You don't have to tear up the dented tank, sell it and go from there.
    I believe Moon still sells the old style filler bung.
    If not in the catalog, perhaps on the back of the shelf in a dusty box.
    Take note that some of Moon's little tanks use a radiator cap and they may fit a standard gas cap.
    That bung may be an available part.
    I'd try to machine a new filler neck similar to the old one.
    Another way around it would be to machine a threaded filler neck, make a simple round cap and JB Weld a gutted cap over the aluminum round cap.
    Seal it with an O-ring or small oil filter rubber gasket.
    Just got done making a couple of threaded aluminum bungs, base, retaining ring and caps.
    They work well.
  28. Oilcan Harry
    Oilcan Harry
    from INDY
    Racecars and race parts have a rough life. It just shows the the part has some history or, at least fell off the work bench. lol Either way I'd leave it as it is.
  29. simon g-s
    simon g-s
    If I bought a new one I'd put some dents in it, it would show up the rest of my heap otherwise !!!!
  30. zman
    zman
    from Garner, NC
    I wsa thinking ne of the Painless Dent removal tools...
    and it seems Frank made his own...
    either way is fine. If I had the time I'd probably fix it, but would be fine running it like that as well.
