67-72 F100 9 inch help!?!?
Discussion in 'The Hokey Ass Message Board' started by HotRodBen1987, Oct 30, 2009.
  1. HotRodBen1987
    HotRodBen1987
    Hey guys I have a 9 inch rearend out of a 1967-1972 Ford F100 that I am needing some information on. I know nothing about these and was wondering what different spline axles came in these, if there are different bearing or housing sizes, differences in differentials, or anything else important I need to know. Also is there any way I can be sure that this rearend is actually out of one of these trucks (someone just told me it was). Any information would help, I am just not sure how many different ways these rear ends came. Thanks!
  2. CreepyCreeperson
    CreepyCreeperson
    from stockton
    kevinstang.com is pretty good with pictures and descriptions.
  3. TooManyFords
    TooManyFords
    from Peotone IL
  4. 36 ROKIT
    36 ROKIT
    They came with bigger bearings and brakes than the cars and featured 28 spline axles;
    31 spline were optional, as I recall. Look for the tag, should be on one of the back side
    diff. bolts - will also give you the ratio.
    I have one under my '36 coupe; very tough unit......
  5. MN Falcon
    MN Falcon
    I had one for sale a while back:
    http://jalopyjournal.com/forum/showthread.php?t=285704
    Synopsis of the measurements I had from in the ad:
    "When this was ***embled the wheel mounting surface to wheel mounting surface was about 61". Spring center to center is about 40" (flange to flange measures 56 3/8" -- I know it doesn't matter) The brake setup was 2 1/4" x 11". The axles are equal length (30" from wheel mounting surface to the end of the axle) 5 on 5.5" bolt circle."
    Basically all of the f100 9" rears have the same width and spring spacing from '57-'72. What makes the '68-'72 really is the brake setup. Mine had the 31 spline axles, it did not have the original center section though and I am not too sure what gears were available
  6. HotRodBen1987
    HotRodBen1987
    Alright thanks for all the help guys preciate it
  7. bluebolt
    bluebolt
    from Benton LA
    1967 rear axles have the same 1 3/4" wide brakes and axles as 1966 and earlier F-100's and are I believe 1/2" narrower overall as well. 31 spline axles are very rare but are out there.
