Dome V. Dish
Discussion in 'The Hokey Ass Message Board' started by Hoffy The Welder-Man, Nov 7, 2009.
  1. Hoffy The Welder-Man
    I Just tore into the block of my 460 to find it came stock whith dished pistons. I am trying pupm ou moer hp and torque and wnat to keep the stock heads. so my question is would domed pistons add more horses and if so would i have to get heads with a bigger combution chamber.
  2. M.Edell
    M.Edell
  3. M.Edell
    M.Edell
  4. Hoffy The Welder-Man
  5. Hoffy The Welder-Man
    Heres the combustion chambers on the heads. The Tans fluid is just for size comparison
  6. Like Max points out, do some calculating first.
    You may do just fine with flat-top pistons.
    455 BB Buicks have a slightly bigger dish and I understand that flat-tops will take a 9.0/1 CR Buick engine to 12.0/1 CR.
    Stock 455 Buicks have a 4.312 bore fwiw.
  7. Hoffy The Welder-Man
    Thanks Maxwedgehiminut.
    Milling seems to bee a good option.
    Is there Any danger in using domes and milled haeads?
  8. M.Edell
    M.Edell
    Of course, you need to know the Valve/Piston clearance..this is done by the "Clay Method" usually.Not too familiar with the Big Ford, you might seek the help of a Ford and or engine expert.Removing material from the head could cause alignment issues with the intake manifold as well.Really need to do some reading and homework.
  9. What kind of car is the 460 going in?
  10. Hoffy The Welder-Man
    Its going back into My F250 if i cant find anything better
    im also changing the rear end from a dana 60 to a ford nine inch
  11. Rooney00
    Rooney00
    Also, 68-'72 heads have a 72-77cc chambers, better ports, and stud mounted rocker arms. Those will bump your compression with the stock pistons.
    Stock pistons and the smaller chamber heads should make around 9:1 CR
  12. Hoffy The Welder-Man
    i have been wanting to find a bucket T or ford sedan To put that motor in
  13. Hoffy The Welder-Man
    I Lokked into it and this motor has a compressin ratio of 8.5 to 1
