Model A 3W proposition
Discussion in 'The Hokey Ass Message Board' started by freeze plug, Nov 7, 2009.
  1. freeze plug
    freeze plug
    from Canton, CT
    Let me preface this by saying I have no money. I can't afford to find a complete roadster or coupe body, so I am going to make a mut. I know it will be a lot more work than finding a complete body, but I have some time and patience. I have been thinking about how I want to go about making my body, whether it be a roadster, coupe, sedan, pickup, etc. I saw a thread recently about a model a 3W made from a certain mixture of parts :
    http://www.jalopyjournal.com/forum/showthread.php?t=394403&highlight=model+pickup
    I have thought about it and here is what I am thinking. proposed sections to be used are circled
    I have the cowl and roof panel from a 1931 model A pickup. I say use this cowl, visor, and front half of the roof skin (stop when midway through the door)
    next, I have a set of rear roadster quarters. While they arent ford, they are very close in dimension.
    last, the rear section of a 2 door sedan cut across the middle of the rear window section. this would need to be aquired still.
    Here is what I came up with, a VERY rough idea of how these parts would mesh together. other than a slight chop, I kept the pieces that I "cut" out proportional to one another, as if I was actually cutting them out of metal and moving them around.
    looks kinda cool.
    and the example someone posted in that other thread, for reference:
  2. freeze plug
    freeze plug
    from Canton, CT
    anyone have any thoughts or input? or other styling cues/pieces that would work any better?
  3. pitman
    pitman
    Certainly worth a shot. The round at the door's upper rear window frame throws me, but otherwise looks good
  4. freeze plug
    freeze plug
    from Canton, CT
    yeah the round is from the sedan rear section, I am sure I could get around that area by cutting it out and returning it to a 90 degree angle, like all other doors
  5. C. Montgomery
    C. Montgomery
    the door looks too short to me?
  6. pitman
    pitman
    I think you'll want to look into the widths in the base of the roof, to the front top roadster quarters. Maybe mock up what you can, and make a horizontal "C" template that fits the roof, then carry it over to check the fit w/the quarters, set up on a mule or frame.
  7. PeteFromTexas
    PeteFromTexas
    Longer doors and smaller space behind the windows.
  8. 31modelo
    31modelo
    Different size beltlines, contours, but somebody has made one from hand so keep us posted as you progress.
  9. madpole
    madpole
    looks pretty good on paper. i actually like the rounded back corners on the doors, as long as it has a good curve to the roof. on similar projects i have seen, the roof area behind the doors ends up looking bulky. maybe a little wider doors would look better.
  10. freeze plug
    freeze plug
    from Canton, CT
    thanks for the replies. heres a quicky with a more extended door and squared off upper corner
    madpole, i kinda like the rounded corner too since it flows with the roof curve.
  11. coupster
    coupster
    from Oscoda Mi
    I would really miss my quarter windows.
  12. freeze plug
    freeze plug
    from Canton, CT
    i was also thinking of that issue.
    i mean, if it came down to it, the optimum thing to do would be to find a 5W roof skin with the rear window frames still intact. however they are harder to find than tudor sedan stuff
  13. justabeater37
    justabeater37
    I have been having the same thoughts about some of the parts I have laying around here as well. Definitly longer doors and less roof behind them.
      46.1 KB
      105.2 KB
      123.6 KB
  14. kb cookout
    kb cookout
    HI I have these section from a blind corner 4door sedan, they maybe fit in with your trying to do
    later kb
    [​IMG][/IMG]
  15. freeze plug
    freeze plug
    from Canton, CT
    hey KB this is austin, you got those '38 fenders from me a week or so ago. how was the rest of your trip?
    i will consider those panels but i'm going to see if i can find some closer at the moment
  16. greaser
    greaser
    I like your second attempt with the xtended door having square corner.
    Maybe add vinyl on roof for the leather back look.
    Henry should have built one!
  17. lockwoodkustoms
    lockwoodkustoms
    The best thing for this would be to find a pair of Model A Vicky doors they are longer than any of the other model a doors but you would have to change the post in the front being they are slanted back
  18. RodStRace
    RodStRace
    The second shot is much better in proportion. However, look at the seat outline and figure out where your head would be. Looks like you will have NO side vision!!!
    As mentioned, the roof width to quarter may need some work, but it looks like the biggie will be the roof area.
    Good luck on this, there have been amazing things pulled off here!
  19. freeze plug
    freeze plug
    from Canton, CT
    hmm vicky stuff will probably be hard to find and i would probably feel mad modifying them.
    here is a sport coupe, for reference. I think the door looks too short for sure
  20. freeze plug
    freeze plug
    from Canton, CT
    thanks for your opinion. i'll take a better look at the seat outline. it seems like side view may be kinda scary!
  21. Toner283
    Toner283
    Henry did build at least one. There are pictures of a prototype 3 window 30/31 in a model A book my dad has. I will see if I can find it & scan the pic. I cannot remember why it was not built, depression maybe? The proportions that freeze plug has in the drawing with the squared & longer doors are pretty close to what Henry had IIRC.
  22. I think it can be done... you might want to give this a look.
    http://www.jalopyjournal.com/forum/showthread.php?t=312050
    Example... maybe someone can photochop it and "stuff" to give you a better idea of what this would look like as a rod. Looks like something similar to what you are describing.
  23. freeze plug
    freeze plug
    from Canton, CT
    WOW!!!!! thanks for the link! amazing stuff
    even has a small round to the rear upper door!
    and looks like a poorly thought out sedan rear section as I was thinking of
  24. freeze plug
    freeze plug
    from Canton, CT
    ugh looks like the silver one i posted above may not be so cool....
  25. doctorZ
    doctorZ
    i think it can be done and you are certainly on the right path. whether it will look better than a five window is all up to taste.
  26. freeze plug
    freeze plug
    from Canton, CT
    i'm not sure it would look better than a 5 window either. its just something a little different that I might be able to pull off keeping a really tight budget in mind
  27. customizer2024
    customizer2024
    from niles, mi.
    If you like it ,build it. It's all about your expression. It will be fun and different, and i'm, all about different. Go to work and start creating. Can't wait to see it. I'll park mine next to it.
  28. Chris
    Chris
  29. The37Kid
    The37Kid
    The guy stated he isn't rollong in extra cash, Vicky doors are rare and costly.:)
  30. 63Compact
    63Compact
    Three window A coupes look like an Es***. Why not use your rear section and the pickup cowl and doors with a soft top like a Cabrolet.
