'40 chevy pickup and master cylinder
Discussion in 'The Hokey Ass Message Board' started by Dan, Nov 9, 2009.
  1. Dan
    Dan
    We put a SBC/T350 in our '40 chevy p/u. Thought we might be able to use the stock underfloor pedal but it hits the bellhousing of the trans. What are you guys using for pedals in similar situations?
  2. shadetreerodder
    shadetreerodder
    I used the stock pedal ***embly and I am also running a clutch with an Ansen ****tershield. All this and a big block to boot. Fits like stock and works great!
  3. burl
    burl
    from Minnesota
    Check out the stovebolt.com site.They have some tech pages on this.I am using my modified stock mount with a late model dual master cylinder for early 60s chevy truck.Running drum brakes front and back.
  4. swade41
    swade41
    from Buffalo,NY
    I used a Master Power Brakes setup with a big block and th400, it's really tight but fits.
  5. budd
    budd
    you must have your motor set back quite aways, i have a 45 gmc with a 250 and a 3 speed saginaw, i use the stock pedals, so i had to make a bracket that bolted to the side of the trans to mount the posts that holds both the clutch and brake pedal along with a duel master cylinder. heres a pic of when i was thinking up a plan of attack.
