Penetrating Oil Showdown!!!
Discussion in 'The Hokey Ass Message Board' started by Abomination, Apr 8, 2009.
  1. pq55
    pq55
    Let-go was made by Krylon, but we can't have it anymore.Now i use deep creep by seafoam and PB.But nothing beat a set of torch.
    Pat
  2. LZ
    LZ
    Ya Pat you got that right..
    Around here they use so much Salt that your car underneath is trashed in a few years.:(
  3. dudley32
    dudley32
    that stuff works...I turned over a can of it, by mistake, in my car...and the next morning....everything down-hill had dis***embled...!!!
  4. Greasy64
    Greasy64
    Justice Brothers makes a rust penetrant/lube called JB 80 "twice as good". Anyone else use it? This stuff is also a rust inhibitor and is great because it is thicker than the others and isn't an acid. Zeke Justice gave me a can 20+ years ago and I have had a can or two handy ever since. I will test out the acetf tonight though.
    Great thread
  5. greasy50chevy
    greasy50chevy
  6. lippy
    lippy
    from Ks
    Ok, this may sound nuts, but....My Dad use to restore old one cyl open flywheel gas engines. One of his buddies told him to go to the drug store or health food store now, and buy a bottle of Oil of wintergreen. Get a small syringe and use it on rusted bolts and nuts. Doesn't take much. I tried it and was amazed. Stinks like evergreen trees, but works great. And fast. If a bolt or nut is tight, not rusty, it won't help much, just like the rest of the penetrants. But if it's rusty it's great. It's pretty expensive for a little bottle, like I say, use it sparingly. Doesn't take much. It's poison, don't take it internally!! Try it, my buddies said, your nuts. I said...try it. I ain't nuts no more. Lippy
    chevylady and Jakesrocks like this.
  7. old 52
    old 52
  8. Locomotive Breath
    Locomotive Breath
    from Texas
    I recently mixed up a batch of approx. 75% Ultra Low Sulfur Diesel and 25% 15-40 motor oil because I ran out of everything else I had at home and didn't feel like going to the parts house. I put it in a little squirt can and to tell you the truth it works better than anything I have bought off the shelf lately.
  9. isnt marvel something like ATF and wintergreen oil???
  10. juanski
    juanski
    "home brew"has allways worked best . gose down smothe to.
  11. Abomination
    Abomination
    Here's an MSDS with the ingredients! ;)
    http://hazard.com/msds/f2/bpj/bpjhk.html
    ~Jason
  12. cornfieldrodder
    cornfieldrodder
    Kerosene, brake clean and isopropyle, That seems easy enough. Theres no recipe, but maybe the ratios aren't very important from a home made point of view.
  13. 3dnsouth
    3dnsouth
    from North Ga
    Kroil all the way! I've had nothing but great results. Got rust?? Ain't skeered!!!
  14. The 111 trichloroethane (TCA) in there is something that would be tough to find anymore because they banned the production of it about ten years ago. Last time I checked it was over $95 a gallon. It used to be a great degreaser solvent used in vapor degreasers, but they banned production of it because it was destroying the ozone layer. They have come out with a few other chemicals to replace that, but they're all expensive, and not something you're going to find in a hardware store.
  15. Abomination
    Abomination
    Ah!
    That's likely the key as to why they no longer manufacture it... bummer.
    Why is everything that's good, not good for you? :(
    ~Jason
  16. Quickponey
    Quickponey
    I did a similar test on my own 3 years ago with everthing listed except for LPS (forget the number). The Kroil outperformed everything including the brake fluid/acetone combination. I had the timer set for 1 hour of soak.
    #2 was Liquid Wrench. Amount needed was 2-3x that of Kroil.
    #3 was the LPS (I think it was #5). This stuff is hard to find.
    #4 was the Acetone/brake fluid mix. This was a mix that I had in a bottle for 2 years or so. Not sure that mattered but thought I would mention.
    I use Kroil for the fine work where an overnight soak is overkill. Kroil does seem to look dry when cured overnight.
    The acetone/brake fluid or ATF is good for working large areas that require an overnight soak.
    Never, ever use WD 40 on anything! I see people spraying this stuff on 1000,00+ fishing reels and even bait! Yuk, why not just use m80's tied to a rock!
  17. Zurekbrau
    Zurekbrau
    Homebrew is all I drink.
  18. marks914
    marks914
    Alliance Vendor
    I am a fan of Kroil, but I will try the home brew. a 74 year old car has plenty of test areas.
    Mark
  19. rodknocker
    rodknocker
    I have used most of the top brands of penetrating oils for years working in NY and was a huge fan of PB Blaster until I found this stuff http://www.crcindustries.com/hd/content/prod_detail.aspx?PN=05002
    Works completely different than most penetrating oils, read the write up on the web page, it freezes the rust instantly and it cracks. We actually have a Mazda Technical Bulletin at the dealer that specifies the use of Freeze Off for any repairs where rust might be an issue, usually exhaust work. This is the most impressive stuff I've seen in a long time.
  20. Idlzruf
    Idlzruf
    Howabout cola I always heard it worked wonders.
  21. Now this is what I was thinking.
    If ATF is good, wouldn't Marvel Mystery Oil and acetone be even better? Marvel Mystery oil on it's own does pretty good. Thinned down it'll probably seep everyplace.
    I have a gallon of Kroil that'll probably last me 5 years. Worked great freeing up old flatheads.
    I'll have to try a new mix on another stuck flathead.
    That CRC Freeze-off looks worth a try.
  22. Airborne34
    Airborne34
    from Texas
    Interesting, my luck seems to fall in-between none and liquid wrench....<O:p</O:p
  23. MN Falcon
    MN Falcon
    :D I use nitrocellulose embedded membranes in my job. One time I got chewed out by the people in the office because the company accidentally sent my order to them instead of the lab, they looked at the DOT stuff on the outside of the box and quickly wondered why I was ordering explosives in the lab:eek:
    I do like the humor there though, all you need is an ignition souce with the mixture and that stuck bolt will not be a problem.
  24. The37Kid
    The37Kid
    WOW! Mabe I can take the door hinges off my 1930 Model A Roadster after all. THANKS!
  25. Milhouse
    Milhouse
    from RI
    So I just tried doing a 1:1 mix of ATF and acetone and they don't seem to mix together at all, the acetone is just floating on top of the ATF. Am I doing something wrong or did I use the wrong type of ATF? I'm using DexMerc ATF made by Coastal as it was the cheapest I saw at the store.
  26. Krabman
    Krabman
    I use this stuff called "Free" by Cetrified at the shop. Works pretty damn good, much better than PB anyways...
  27. lippy
    lippy
    from Ks
    You guys are making this too hard. Get a little bottle of oil of wintergreen and you don't need to be mad scientists and mix all this stuff.:D Plus your shop will smell nice too.:D
    MrEarl and Jakesrocks like this.
  28. Jakesrocks
    Jakesrocks
    What lippy says. Oil of wintergreen. Best damned penetrating oil ever.
    Back in my early Navy days. Back in the days when they still used landing craft with Grey Marine engines, frozen clutches caused by salt air in hot tropical regions was a big problem. The throw out bearing would rust up solid on its steel sleeve. Also, the clutch dogs on the multiple disc clutches would freeze up. Quick trip up to sick bay for a squirt bottle full of oil of wintergeen. Squirt a little on the frozen parts. Wait a couple hours. Work the clutch lever back & forth a few times, and good as new. Not only does this stuff work great, but it makes your ride & shop smell great. Mice & spiders hate the stuff, and will flee the area. No more chewed up wires or upholstery.
    Since retiring from the Navy, I've always kept a bottle of oil of wintergreen around for those stubborn jobs. WD-40 & the others work great for squeaky door hinges and things of that sort.
    MrEarl likes this.
  29. Slopok
    Slopok
    For those of you still having trouble finding Acetone, it can readily be found at Ace, Menards and Home Depot.
  30. Jakesrocks
    Jakesrocks
    Acetone can also be found at boat and other supply places that handle fibergl*** supplies.
