What's this yellow stuff holding my oil pan together?
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Nov 13, 2009.
  1. Just Gary
    Just Gary
    My Hemi oil pan started as a center sump. A forward sump was added sometime in it's history. The addition was lapped over the original pan and glued(?) with some kind of yellow stuff. It's impervious to a propane torch so I don't think it's brazed. Is it epoxy, or what?
    Is there some way to remove it, short of cutting the whole thing apart?
  2. WOW! Looks like some epoxy. Like JB Weld but wrong color.
  3. RAY With
    RAY With
    Looks likr it was braized to me and looks like br***. You need motr heat that a little propane torch to melt it.
  4. 8-Track
    8-Track
    It Lookslike it was Brazed to me,What does it look like when you grind it?
    I would look for anew oil pan.
  5. plym49
    plym49
    from Earth
    That's not braze is it? Just asking.
  6. skullhat
    skullhat
    looks like br*** to me. either way, epoxy will break up with heat as well.
    get out the torch and a wire brush
    skull
  7. Big Dad
    Big Dad
    Ha,ha,ha,ha,ha,ha
    kids today
  8. chevyshack
    chevyshack
    Looks kinda like liquid nail. Seen an episode of pimp my ride where someone took 2 halves of a ford ****** and welded the top but used liquid nail to glue the bottom side half together.
  9. winr
    winr
    from Texas
    Lol........:D
    Scratch it with an awl or something, if it is br*** it will scratch and be shiny..well shiny br*** looking.:)
    Ricky.
  10. fab32
    fab32
    From the pictures it looks just like the brazed joints that have been used for years by bodymen who couldn't weld.
    Frank
  11. Big Dad
    Big Dad
    My big ol' belly hurts ... knock it off
  12. lostforawhile
    lostforawhile
    braze,i've even seen some factory ones with braze holding them together.
  13. Just Gary
    Just Gary
    Thanks, guys!
    So what's the best way to remove the brazing? Heat? Twisted wire wheel on a 4 1/2" grinder? Other?
  14. Big Dad
    Big Dad
    You will have to cut off what you don't need / want and put new pieces in where they need to be or find another pan to work with
    Its bronze rod welded , instead of using steel for filler
  15. Sellers Equipped
    Sellers Equipped
    from San Jose
    Hey Gary you remove the Brazing, the lower section of the pan will fall off, looks like your pan was smashed at one time, and someone scabbed in another section for the repair. Find a new one or leave it alone. Map gas will melt the brazing
  16. dannyego
    dannyego
    why not just get a new pan??
  17. crackerass54
    crackerass54
    from dallas
    why do you want to take it off? if it isnt leaking then leave it. that is not a sketchy way to do that, brazing is relitivly strong and I don't think you will have any issues with it and to be honest I kind of enjoy seeing some brazing around, adds caracter.
  18. captainjunk#2
    captainjunk#2
    its brazed if it was of a chemical composition it would have started to burn in some way shape or form
  19. Hotrod1932
    Hotrod1932
    from Oregon
    Looks like **** to me...LOL
  20. plym49
    plym49
    from Earth
    Tell you what - now that you have sandblasted that pan there is grit and **** underneath that raw inner edge. Not the best and it can be really hard to get it all out - some will tend to remain and then free itself some time in the future after the motor is back together. The correct procedure would be to braze up the inside, too.
    Other than that there is nothing wrong with that pan.
  21. skunx1964
    skunx1964
    whats the oil capacity on that now? 8 or 9 quarts?
  22. lippy
    lippy
    from Ks
    Beat the edge down inside and braze it up. Nothing wrong with that pan. Coat of paint......down the road.:D
  23. von Dyck
    von Dyck
    If you manage to get the two pieces apart, you will not be able to fusion weld it back together where once it had been brazed. Leave it as is. Do a thorough clean-up and use it.
  24. Baby or calf **** yellow? :D
  25. edgeabilly
    edgeabilly
    I say get a new pan.
