Art & Inspiration The Mother Of all Dash/Gauge Threads!!!
Discussion in 'The Hokey Ass Message Board' started by JeffreyJames, Oct 22, 2008.
  1. LBCD
    LBCD
    41 ford..........
  2. moparforlife
    moparforlife
    from Rolla, MO
    '60-'62 Chrysler I believe.
  3. 38FLATTIE
    38FLATTIE
    from Colorado
    Here's mine, for my 38 Lasalle. 34 Plymouth gauges. All electric switches are behind the driver side cubby hole.
  4. 28Abone
    28Abone
    from Toronto
    Here's one I made from different pieces for my 28 coupe......
    Dennis. :)
  5. 47Ford - 1.5Ton
    47Ford - 1.5Ton
    What it is....
    What it will become....
    Covered Fighter switches are Start, Fuel Solenoid, and a Master
    The other 3 on the sub panel are air suspension swtiches firing solenoid valves...which also need to have covers.
  6. philly the greek
    philly the greek
    from so . cal.
    here's the dash that we made , before and after upholstery
  7. Stevie Nash
    Stevie Nash
    I don't think there is anything cooler than retro fitting a 50's dash into a pre-50's hot rod!
  8. well mines no where as cool as most here,I wanted to redo the dash in my 56 g***er/street freak yet keep the sorta stock look to the panel an period correct to mid 70s when the car was built,I made the center piece outa aluminum and painted it to look like a stock dash(insert in stock trim) I wanted to move the gauges up into the panel and add a volt meter,some one had added a pull out deck in the early 80s so I junked it and moved the Kenwood am/fm c***ette.cd changer controler over to the right about 3 inches,then put the lighter all the way to the right instead of next to speedo (phone power) oh yeah added a K-Mart (new) 8-Track under the dash just for looks.........now I gotta find a 56 chevy lighter:rolleyes:
  9. FinnishFireball
    FinnishFireball
    I made mine like this
  10. LOST ANGEL
    LOST ANGEL
    WOW, that is ***s!!-MIKE:eek::cool:
  11. freebird101
    freebird101
  12. 52HardTop
    52HardTop
    Well mine didn't take as much designing as most of the others. Just some Auto Meter gauges and clock in my 51 convertible.
    Dom[​IMG]
  13. 48cad
    48cad
    Here's the one out of my car. I had to keep the stock cluster.[​IMG]
  14. WEBSTER
    WEBSTER
    from Tacoma, Wa
    Hi: What is he diameter of the hole for the speedo?
    Might be able to help! Terry
  15. WEBSTER
    WEBSTER
    from Tacoma, Wa
    Hi: What is the diameter of the hole for the speedo?
  16. youngrodder1929
    youngrodder1929
    iv always liked this one
  17. Fighter-of-Wars
    Fighter-of-Wars
    Here is the stock setup in my 1943 Ford Truck. I believe this is the way they came from the factory for military use. All Stewart Warner Gauges. All still work, and I think some may even be original. Those 2 things to the left and right of the speedo are lights that shine down.
  18. SB5332
    SB5332
    from NEW YORK
    Here's one i made from a sewer pipe and holesaw plugs
  19. aircoup
    aircoup
    I just noticed a moon column drop on this thread i have one also buddy of mine picked it up at a garage sale for 2 bucks does anyone know when these were made?
  20. super plus
    super plus
    I like this :) one
  21. bamaheel
    bamaheel
    [​IMG] [​IMG] [​IMG]
    My Twin Blue's in a Hollywood panel
  22. revkev6
    revkev6
    from ma
    hollwood panels are HUGE! I have one and can't imagine what I would put it in....
  23. HanelineJake
    HanelineJake
    some experiments with br*** and copper.
  24. 5Wcoupe
    5Wcoupe
    from L.A., Ca.
    How 'bout the Jim Busby coupe-
    Pretty much perfect, just like the rest of the car.
    getow likes this.
  25. HanelineJake
    HanelineJake
    Found this one at a Concours event in Newport Beach, CA.
  26. alfin32
    alfin32
    from Essex, Ma.
    Lincoln KB w/ late '40's SW in a Deuce 5W dash.
    The insert itself is going to be vertical black and silver stripes
    like on a '53 Caddy dash.
  27. exStreamliner
    exStreamliner
    Here is a work in progress... cutting the holes tonight... two 5" and six 2.25" in a 27 Roadster
  28. exStreamliner
    exStreamliner
    Gauges in Place
  29. dodored
    dodored
    from Concord NC
    Here is a Hudson Jet dash put in a 1934 Ford Pickup. Took about 10" out of the middle. Thought the gauge pod was cool.
