Do 39' Ford car Pedals fit 39' P/U ?
Discussion in 'The Hokey Ass Message Board' started by C300, Nov 4, 2009.
  1. C300
    C300
    from Wa.
    Hi, Was wondering if 39' Ford car Pedals fit 39' P/U ? My cab came minus them. Will be using ( modifing )the original frame. seems to be more car pedals available. Thanks, C300
  2. 36tbird
    36tbird
    Frames are the same, p***enger and pickups. I have a rebuilt pedal set up with adapter and Mustang master. If you need one, PM me.
  3. FYI. Bob Drake, http://www.bobdrake.com/, is reproducing these pedal ***emblies now. I haven't seen them.
    Charlie Stephens
  4. C300
    C300
    from Wa.
    Great ! Thanks a bunch. When my used front end (and Brakes) gets here, I'll size it up and make a choice. I'm betting used, see how much room...
  5. 36tbird
    36tbird
    Charlie, where are Drake's pedals made? Wanna venture a guess?
  6. C300
    C300
    from Wa.
    Charlie Stephens: thanks, I looked in Bob Drake's link and didn't/still do not see any petals. Will contact Him.
    36tbird: sounds like your in buisness (outside San Antonio). I heard that 39' and 40' have different clutch linkage setups. is there a preferred setup for different tranys ?
    Thanks,C300
  7. Greezy
    Greezy
    What transmisson are you running? The 39s are more desireable, but if youre running a newer trans, 4 or 5 spd and are going to need to modify the pedal, a set of 40s will work just fine.
  8. C300
    C300
    from Wa.
    Running a standard, I have a A-833, S/B Bell(Plymouth), a T5 S/B(chev.)and an old toploader ? no bell(ford). Got 2 addapters, 331 Hemi to ? Haven't had everything unpacked at the same time to fit-check. The 39' ford P/U is gonna be low, and running a Champ QC. I was hoping that one addapter was mopar since its the smallest, and have the most parts. T5 would be overkill, but lighter.
    Trying to get the main build parts together so I don't wait 2 weeks for some part once I get on a roll. Wish I had a pix of the 2 side by side, C300
  9. pasadenahotrod
    pasadenahotrod
    from Texas
    The 39 pedal ***emblies desireability hinges on the fact that it is a easy "bolt-in" to convert 35-38 Ford cars and pickups to hydraulic brakes without having to fab any clutch linkage since it works exactly like the 35-38 pedals do.
    The 40 pedal ***embly will fit as well but the 40 uses the clutch release arm in the bellhousing which has the slot end and the equalizer cross bar mounts to the frame rail on a ball bracket with split bushings.
    That is the simple reason the 39 is "legend". Add the fact that it was used in only ONE year of cars/pickups and there you have the rarity.
  10. C300
    C300
    from Wa.
    Pasadenahotrods, That sums it up nicely ! Thanks for sharing, C300
  11. 36tbird
    36tbird
    C300, I'm not in business but I did collect a few '39 pedal ***y's.
