stewart warner gauge panels
Discussion in 'The Hokey Ass Message Board' started by revkev6, Oct 31, 2007.
  1. COOP666
    COOP666
    from Austin TX
    Here's mine:
    Speed~On likes this.
  2. Not SW but I thought this page of M@@N panels from 1962 is pretty cool.
  3. Harrison
    Harrison
    Several years ago I bought a 5 gauge AC panel, like the one Kaydub has pictured above, for $5. $$ was tight & I had to sell it. Wish I had it back now.
    Anyone have one for sale? Kaydub? I don't want gauges, just a panel.
    Great thread.
    JH
  4. Carter
    Carter
    Not a Stewart Warner panel , but I do like it a lot. Obviously a boat panel, unsure of age. Only ever saw 1 other one like it, but it said Chrysler powered, otherwise identical. Would rather have had that one, since I don't anticipate ever having a Nordberg powered car. Oh well..
  5. denis4x4
    denis4x4
    from Colorado
    This is a Lokar '32 insert with an original '32 speedo combined with new S-W Wings oil pressure, tach and Volt meter. Knobs are So-Cal and I'm using the So-Cal keyless starter for a clean look
  6. Gas_Tires_Oil
    Gas_Tires_Oil
    Does anyone know where I might find P/N and intstallation instructions? I found a set of non- marked SW gauges at a swap meet that I was hoping to use but I'm really not positive that they are 12 volt. They don't have rear light bulb holes but rather side windows for bulbs to shine through.
    EVL401 likes this.
  7. alchemy
    alchemy
    Your set looks like OEM from a 56 or 57 Studebaker. Some hipo model like Golden Hawk or somesuch. Probably 12 volt as most manufacturers switched in 55 or so.
  8. Gas_Tires_Oil
    Gas_Tires_Oil
    I wish I paid more attention to what the guy said they were out of. As soon as I asked the price someone else almost grabbed them when he said $25 for the set. I said I'll take them and the deal was over in seconds.
  9. alchemy
    alchemy
    On second thought though, your gauges may still be six volt because SW made a lot of six-volters for years after the OEM's went to twelve. Might have used a shunt in the Studey. A lot of Ford products used six-volt gauges and a shunt into the 70's.
    Can you list the numbers on the back of these gauges? I may be able to look up the application, and maybe the correct sender they require.
  10. Bruce Lancaster
    Bruce Lancaster
    Stude SW...I dimly remember one of the catalog places, probably Honest Charley, selling complete Studebaker panels with SW gauge set, probably very early 1960's. They were factory surplus from a production overun (or I guess underrun of actual car production).
  11. Gas_Tires_Oil
    Gas_Tires_Oil
    Thx alchemy. I'll go to PM's to let you know so as not to take away from the thread.
  12. 29bowtie
    29bowtie
    Coop is that from a Franklin? The"Powered by Lycoming" is the reason i ask.
  13. alsancle
    alsancle
    I would imagine Auburn if it was powered by Lycoming. Didn't Franklin build their own engines since they were air cooled.
  14. 36C8
    36C8
  15. 36C8
    36C8
    The bottom one is another example of the GM Diesel panel, a "Straight Five" version of the ten gauge panel on the previous page. The GM insignia would have been on the crescent, but looks like someone rubbed it off...
  16. 36C8
    36C8
    That was me. I needed the tachs for another panel. Muntz did use a special-insignia version of the Hollywood.
  17. chris1932
    chris1932
    Dudes, half of those damn panels shown came out of my stable! That 10 gauge panel is a monster and weighs about 10 pounds!! It is an AC (BUILT BY GENERAL MOTORS FOR A BOAT). Some of those other pictures are from my panels over the last year. What do ya want to know?????
  18. Squablow
    Squablow
    This is mine, I guess it's the Ensign model. Has some old curved gl*** wings gauges in it along with a no-name speedometer and a flat gl*** SW air pressure gauge. Wanna buy it?
  19. Bruce Lancaster
    Bruce Lancaster
    Yeah, I do! I'm still digging in my archives...think I can produce some '48-52 hotrod catalog data on what was available then. I have one little SW flyer actually directe to hotrod use, but I think it's later '50's or so. Someone must have noticed there were lots of sales not going to stationary motors!
  20. Jack Kendall
    Jack Kendall
    Stewart Warner offered a stainless steel, "Eight In A Row" gauge panel in the 1955 issue of "The Newhouse Special Parts Catalog." They call it the "Special" I have one installed in my 32 five window. Dave Cook installed one in the red three window that is currently owned by Bruce Meyer. You don't see many of these, but they look great in 32 Fords!
    EVL401 likes this.
  21. Deuce Daddy Don
    Deuce Daddy Don
    Here's some SW's mounted in wood from 1963, they were called "Custom Faced"----Still up in garage attic.------Don:D:D
  22. Deuce Daddy Don
    Deuce Daddy Don
    OOPS! Here they Are!!!!
  23. 32 Barn Car
    32 Barn Car
    from Oregon
    All Stewart Warner , most gauges are curved gl*** . A couple in my cars now , others from the past............Z
  24. Rickybop
    Rickybop
    Just a side note. Did you guys know that some fire-trucks (I think it was the Mack) were equipped with SW curved-gl*** gauges? I didn't, until I read it somewhere in recent years. When I worked at a local tractor/truck/implement yard a couple of years ago, the old owner had one there. When I got the chance, I took a look, and sure-enough...SW curved gl*** gauges. Asked him if I could buy the panel and gauges...the anwer was "No". I'd guess the truck as being an early '60s model. It's still there. I may have to try again. (This time I'll ask his son...shhhh.) - Rick
  25. 36C8
    36C8
    These are all SW truck gauges, White, Reo, LaFrance...
  26. razorback
    razorback
    from Sweden
    Here's a Hollywood panel I got, came with SW gauges in bad shape..a**** others, a 3000 rpm (!!) tachometer.
    I have seen theese in big trucks / busses, anyone know if they were "original" mounted in any vehicals?
  27. radio_king
    radio_king
    I`d say it was original equipment in boats only,introduced in 1948 as "Master"panel(for MasterBaitors...:D)and the name was changed later on when they started to focus towards hot rodders.
    I have a SW brochure from -48 and it has your tach pictured in it.It was available electric or mechanical and with or without odometer.I try to get it scanned and will add it here.
    Does your panel have any painted code on the other side?If so,it tells you the build year.I try to find the link where you can crack the code.
  28. radio_king
    radio_king
    From roadsters.com site:
    Stewart Warner date codes <hr noshade="noshade" size="1">
    <table width="450"><tbody><tr><td valign="top"> Year of Manufacture
    </td></tr></tbody></table> <table width="450"><tbody><tr><td valign="top"> A - 1933
    B - 1934
    C - 1935
    D - 1936
    E - 1937
    F - 1938
    G - 1939
    H - 1940
    J - 1941
    K - 1942
    </td><td valign="top"> L - 1943
    M - 1944
    N - 1945
    P - 1946
    Q - 1947
    R - 1948
    S - 1949
    T - 1950
    U - 1951
    V - 1952
    </td><td valign="top"> W - 1953
    X - 1954
    Y - 1955
    Z - 1956
    A - 1957
    B - 1958
    C - 1959
    D - 1960
    E - 1961
    F - 1962
    </td><td valign="top"> G - 1963
    H - 1964
    J - 1965
    K - 1966
    L - 1967
    M - 1968
    N - 1969
    P - 1970
    Q - 1971
    R - 1972
    </td><td valign="top"> S - 1973
    T - 1974
    U - 1975
    V - 1976
    W - 1977
    X - 1978
    Y - 1979
    Z - 1980
    <table width="470"><tbody><tr><td valign="top"> Month of Manufacture
    </td></tr></tbody></table> <table width="450"><tbody><tr><td valign="top"> 1 - January
    2 - February
    3 - March
    </td><td valign="top"> 4 - April
    5 - May
    6 - June
    </td><td valign="top"> 7 - July
    8 - August
    9 - September
    </td><td valign="top"> 10 - October
    11 - November
    12 - December
    de-fenders likes this.
  29. krylon32
    krylon32
    from Nebraska
    Last year I missed an early Diamond T truck by a few minutes that had all curved gl*** SW gauges in a cool dash that would have been perfect for an early style rod. Day late/dollar short!
  30. Terry O
    Terry O
    Not SW, but if you like that style, take a look here
    http://www.haneline.com/
    I believe he posts here also.
    Terry
