Flattie in a 32
Discussion in 'The Hokey Ass Message Board' started by torqthrusttoad, Nov 15, 2009.
  1. torqthrusttoad
    torqthrusttoad
    I have a 32 roadster and i want to run a flattie.the one i have is a 47 with double groove pulley setups which stick out to far.i don't want to cut the fire wall and i don'tt want to run an electric fan.anyone know what setup i need?
  2. DICK SPADARO
    DICK SPADARO
    Simple, you need the following parts, stock style 32 v8 front engine mounts (avail repro) change the lower pulley to a single 39-40 pulley, stock 37 to 39 fan to attach to a 37-9 generator or new fan mount wide belt pulley for GM one wire alternator and alternator bracket.
  3. HELLMET
    HELLMET
    na just put a 454 bb with a 671 blower on it. it will run much better than that old flathead.
  4. 31whitey
    31whitey
    Spadaro is the MAN.
  5. torqthrusttoad
    torqthrusttoad
    But i'm running multi carbs with offset gen.
  6. banjorear
    banjorear
    You can stll use the fan set-up. You'll need to make a idler pulley set-up and run the fan straight up.
    Takes a little figuring out, but makes sense once you have the parts in front of you. Still run the gen. offset one of the heads.
  7. 28hiboy
    28hiboy
    from Milton, Fl
  8. continentaljohn
    continentaljohn
    This one runs a 51 Merc Flatty with a Granco 3x2 with a Alt in front or it. Its tight but 1/8 inch or room to spare:D
