Factory chrysler flathead 6 dual carb and exhaust?
Discussion in 'The Hokey Ass Message Board' started by Moloko, Apr 20, 2008.
  1. Moloko
    Moloko
    Was in the junkyard today, and there was a 51 dodge fire truck. Had a flathead 6 in it, with factory dual single barrels and dual exhaust (two seperate manifolds). I just thought it was odd. I'm ***uming it was a heavy-duty only kind of thing?
  2. vegas paul
    vegas paul
    from salina, ks
    I've got dual carb manifold and dual exhaust on my Studebaker flathead 6... aftermarket, but not unheard of.
  3. Moloko
    Moloko
    This is for-sure factory stuff on this fire truck.
  4. R Pope
    R Pope
    I've had a couple stock dual carb/exhaust setups for Dodge sixes. Farmers around here tended to pull them off, thinking they were too complicated. They work well if you dial them in right, and the exhaust note is incredible!
  5. mackster
    mackster
    I'm looking for a set up like this for my desoto. it is the longer 25 in. block sort of the same as the chrysler. I guess they call them big sixes. if any of you find one and are willing to sell P.M. with a price and we can go from there. specially if you are getting it from the junkyard!!!!!
  6. tragic59
    tragic59
    My guess is that it was a heavy duty flat six. Much larger than anything they put in cars, and only used in large trucks.
    Seems to me I read something about them once, but can't remember where.
  7. Dale Fairfax
    Dale Fairfax
    What is it that makes you so sure it's a "factory set-up"? In 1951 a lot of independent truckers who used Dodge tractors installed Ellis systems to gain power and, supposed, economy.
  8. plym_46
    plym_46
    from central NY
    This was optional factory equipment 1 1/2 ton and up. Chryco made several big 6's including a 413 cubic inch for over the road trucks. Those truck engine are the long block version so they will fit chyrsler, desoto and Canadian manufactured automobile 6's. The 300+ and 413 6's were 30 or 33 inches long can't remember for sure so their manifolds (a tripple intake was available) were only for those engines.
  9. Moloko
    Moloko
    That first link was the setup it used.
  10. VOLKER
    VOLKER
    My Father had a customer in the early 1950's that had a Dodge tractor trailor with this set up He made a 600 mile round trip to Chicago twice a week. If I remember, the told me it had 413 cubic inches. Got around 5 mpg.
  11. VOLKER
    VOLKER
    I agree. Knocks the heck out of a v6 tone
  12. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Easy; if it's cast iron, it's factory. Chrysler made a dual carb&exhaust setup for the 25 inch Chrysler/DeSoto style engines in the medium duty trucks.
  13. VOLKER
    VOLKER
    If you dig around mopar's site,they will tell you the were equipped that way from the factory. I made several copies of old Dodge (early 50's) factory photos with descriptions off the net. There were at least four different c.i. sizes with the dual carb and exhaust. The largest was 413 c.i.
  14. propwash
    propwash
    from Las Vegas
    Saw this setup in Genessee Idaho on some large Dodge stake truck....that was back in the late 50s...the truck had been around a few years. Guy told me it was factory, but I didn't believe him at the time.
    dj
  15. VOLKER
    VOLKER
    Just found it. Go to OLD DODGE TRUCK BROCHURES and scroll down. You can see one in one of the brochures.
  16. CayoRV
    CayoRV
    Here's a pic of one a buddy of mine and I pulled from an old Dodge dump truck on a farm near here. This thing is definitly a factory setup but I doubt you could get it to fit in a p***enger car or for that matter even a pickup. The head is 33 inches long!:eek:
  17. alsancle
    alsancle
    I was just daydreaming the other day that he factory should have figured out a way to squeeze those bigger sixes with the duals into their wayfarer roadsters. Would have been a cool combo.
  18. plym_46
    plym_46
    from central NY
    Since the the 331/413 Truck engines are 10 inches longer at 33 inches, than the 230, you might need a bit longer wheel base. And at 1000+ lbs, for just the engine some beefier springs and bigger wheels and tires might be in order.
  19. alsancle
    alsancle
    If you cut the firewall will it fit? Hmmmm, sounds like a cool project. Will the truck 4 speed fit back there too or is it too much of a stump puller?
  20. That big truck six would most likely have big truck five speed trans..171 hp & 343 torque
  21. Mooseandsqurl53
    Mooseandsqurl53
    from N.J.
    This was my Grandfather's '54 Dodge road tractor. It had the 413 six in it. The mufflers were gutted, giving it a beautiful sound.
  22. lead54chrysler
    lead54chrysler
    If you go back to that junkyard and pull these parts I would buy them from you just give a good price
  23. I was thinking of a straight 8. My brother has a marine one but now maybe a big six would be fine
    don
  24. Unibodyguy
    Unibodyguy
    Had some nieghbors who's Father bought a 49 Dodge big truck, possibly 3 ton? 10:00X20 tires, it even had air brakes on it and it had the same setup from the factory. Sounded real good with the gl*** packs it had on it. Used to see them at the feed store with it. And 60 mph was no problem for that thing.
  25. pasadenahotrod
    pasadenahotrod
    from Texas
    Easier to shorten the manifolding and use on the smaller engines if the port mounting spacing is the same.
  26. Ever since you guys talked about this i have been dreaming of one. If i wanted to buy a flathead dual carb motor (413 cubes)(. Not cracked is all I ask) Who has one they would sell reasonable near me? A days drive is near i think.
    Don
  27. L. Eckart
    L. Eckart
    My dad bought a '59 Chris Craft boat in 1960 with a 6 cyl. Chrysler with dual single barrel carbs and I think it came that way from the factory. I recently bought it from my nephew who bought it from my dad several years ago. He says he has a manifold for it with 3 single barrel carbs. I haven't seen that manifold yet so I don't know if it is cast iron or not. Would look pretty cool on that flat six.
  28. oldebob
    oldebob
    from Spokane WA
    1954 Dodge truck folder lists dual carb , dual exaust for the 265.37 cu in 6 availible in J6 & K6 conventionals. J was 2 1/2 T, K was 2 1/2 T HD. Shows 13hp gain over the single carb 123hp motor. And 3 hp over the little 241" hemi that was Doge trucks V8 option.
  29. Tim Keith
    Tim Keith
    I think the 331-377-413 series is based on the original big
    Chrysler 7 main bearing six from the 1920s. For compe***ive
    reasons the luxury car market went to straight eights and Chrysler
    enlarged the block design of its big six for use in heavy duty
    trucks. I think the 413 have 5 inch strokes
    In this era Chrysler was selling 4+ ton trucks, which you did not see
    in Chevy and Ford. There was a diesel 331 in about 1939.
    Metalurgical advances allowed for dependable four main
    inline six crankshafts in the 1930s when Chrysler introduced its
    popular line of L-head automoble sixes in two series that we are
    familiar in the cars. The old seven bearing six continued on in
    large trucks.
  30. Here's one in a big truck, in the collection of a guy with lots of old
    Dodge trucks.
