Home Center steering wheel bullet center cap thingy
Discussion in 'The Hokey Ass Message Board' started by Antny, Nov 16, 2009.
  1. Antny
    Antny
    from Noo Yawk
    So I was bored this afternoon and took a trip to one of them Home supply centers, and found myself in the chain link fence section. There on a shelf with the rest of the ugly hardware is a box full of those aluminum post caps. Hmm, looks like it would make a fine steering wheel horn cone! Paid the $5 and off I go to the garage. I cut a ring from some s**** exhaust pipe, and a circular sheetmetal disk, grabbed the mig, and, well, here's some pix. Not bad for 20 minutes of work and $5.
    Here's the fence post cap.
    Here's the exhaust pipe ring and circular disk.
    After welding from the backside and bolted up to the removable steering wheel/hub.
    Cap installed via friction-fit!
    And the finished product installed on the column.
    A little polish, and 1 step closer to finished! :)
  2. temper_mental
    temper_mental
    from Texas
    Man I would be scared of that in a wreck!
  3. pecker head
    pecker head
  4. retromotors
    retromotors
    Sammy Davis Jr. would've loved it!
  5. temper_mental
    temper_mental
    from Texas
  6. Antny
    Antny
    from Noo Yawk
    You guys do wear seat belts, right?! :p
  7. Von Rigg Fink
    Von Rigg Fink
    from Garage
    huh..looks like it came off my fence post..whats up with that?
    im just messing with you..;)
  8. hotrod-Linkin
    hotrod-Linkin
    you should have completed the theme and covered up that nice column with a fence post.
  9. Antny
    Antny
    from Noo Yawk
    lol!
  10. rottenronnie49
    rottenronnie49
    from kalkaska
    i wonder what it would look like in a wheel ,as a center cap?
  11. Antny
    Antny
    from Noo Yawk
    I tried it. It looks great! If I didn't already have baby moons, I'd do that.
  12. hotrod-Linkin
    hotrod-Linkin
    glad you have thick skin and humor!!
  13. Limey Steve
    Limey Steve
    Alliance Vendor
    from Whittier
    That looks ***s :) or *** at least ;)
    nice turn sig switch too
    sometimes you have to think outside the box , that's a nice simple tech piece.
  14. Antny
    Antny
    from Noo Yawk
    Oh heck yeah. And I can laugh at myself too. My psychiatrist says that's good. :D
  15. Antny
    Antny
    from Noo Yawk
    Hahah! I absolutely LOVE the turn signal switch! Awesome quality. It's probably the nicest part of my truck! Thanks, dude!! :)
  16. Hot Rod Bob
    Hot Rod Bob
    from T-ville Ky
  17. thewishartkid
    thewishartkid
    Ilove it! I made one for my T from a bullet i bought at a swap meet.
  18. bobscogin
    bobscogin
    That's what I used on my wheel, but I cut off the "ridge" and everything below it. Sometimes less is more. $1.47 at Home Depot.
    Bob
  19. Antny
    Antny
    from Noo Yawk
    Nice. How did you mount it to the wheel?
  20. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Very cool .Now your fence post is missing a cap I take it.
  21. bobscogin
    bobscogin
    Similar to your method. A plate with a sleeve and hole for a screw to hold the cap on, held down by the bolts that bolt the wheel to the adapter. Here's a not so great photo that was on my iphone.
    Bob
  22. Retro Jim
    Retro Jim
    Now that is a true hot rodder mind at work !
    Good job and way cheaper that the ones at the car shows !
    RetroJim
  23. Antny
    Antny
    from Noo Yawk
    Nah. My neighbors' down the block! :D
  24. Whats the diameter on these??? You say they fit as a center cap on wheels too???
  25. burt banjory
    burt banjory
    That is cool! Great idea.
    **** make a grip of em and sell em on Ebay!! :D
  26. Antny
    Antny
    from Noo Yawk
    The inside diameter is 2-3/8", OD is probably about 2-5/8". To fit my rear axles, I'd need to make a bushing on the lathe; the axle hole is a bit larger. Same for the front, but the opposite; would need to turn an adaptor to fit over the bearing hub. Both would be easy to do on the lathe. Maybe if I get bored again......it would give people more reasons to make fun of me, anyway! :D
  27. striper
    striper
    I like that. Could be a good housing for a tachometer.
  28. Antny
    Antny
    from Noo Yawk
    Yep Or tail light housings.....or for a clock. All sorts of cool ideas! Keep em comin!
  29. Kustom7777
    Kustom7777
    from Austin, TX
    pretty cool idea!
  30. So you'd need to fab something up to press it into the backside of the wheel???
