The Tudor gets an altitude adjustment
Discussion in 'The Hokey Ass Message Board' started by remdam, Nov 16, 2009.
  1. remdam
    remdam
    from New Jersey
    Thanks to Chris and Elrod for the inspiration and to Lowbuckboz for fabbing the brake actuator brackets and helping to bend the steering arms.
  2. doctorZ
    doctorZ
    awesome!! very well done.
  3. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
  4. Gotgas
    Gotgas
    from DFW USA
    Man, you just made my Top Ten Model A list! Real simple, real clean, bravo.
  5. ST. 515
    ST. 515
    from TEXAS
    Man, that looks SWEET!!! Good job!
    -Saint
  6. Von Rigg Fink
    Von Rigg Fink
    from Garage
    now that you have done that to your A...you wont be needing it anymore, so you can pm me now for my address to have it dropped off tomorrow..
    im such a nice guy, i'll even spring for the shipping;)
  7. Ryan
    Ryan
    ADMINISTRATOR
    That is one fine sedan right there...
  8. fab32
    fab32
    Just when you thought you couldn't give a Model A a different "look". Well done.
    Frank
  9. Fenders
    Fenders
    beautiful car. I prefer the smoother body - cowl joining of the 30 - 31 but I love the way the 28 - 29 front fenders caress the tires...
  10. snelson57
    snelson57
    Yep - sits perfect. Thanks for the inspiring pictures....
  11. OoltewahSpeedShop
    OoltewahSpeedShop
    Bad ***!!!! Thats all you can say.
  12. Anderson
    Anderson
    Awesome! Glad to see my brake tab extender idea being put to use.
  13. D-Russ
    D-Russ
    Looks perfect. Got any before shots? What size tires are you running?
  14. Hot Rod Bob
    Hot Rod Bob
    from T-ville Ky
  15. 32SEDAN
    32SEDAN
    Spot on! I vote no chop. Why mess with perfection?
  16. VA HAMB
    VA HAMB
    I like the whole scheme. Very nice.!!
  17. Jersey Joe 67
    Jersey Joe 67
    from J Town
    Totally gorgeous ride my friend. That's how it should be done.
  18. rexrogers
    rexrogers
    I love the way the tires fill the fenders great job any info on what they all did to get the brakes modified.
  19. flatford39
    flatford39
    What did you do to lower the *** end???? You have it perfect.
  20. aussiesteve
    aussiesteve
    I really like that!!
  21. Elrod
    Elrod
    Right on. Lots of similarity. Looks like we're going to start a trend!
    You using Flathead Ted's brake floaters? Is that what's going on with the top adjustment bolt? Been thinking about adding those to my cabriolet.
  22. remdam
    remdam
    from New Jersey
    Thanks for the compliments. This site has been a huge inspiration.
    Here's the lowdown on the build:
    Front: 4" drop axle from Okie Joe Axles
    Reversed eye main leaf
    Rear: "T" spring with 3 and 5 leafs removed.
    I used an ol spring an i believe it is just plain worn out.
    It is way too soft. I am going to add a leaf back in but
    may end up replacing with a new spring. I also plan on
    adding some shocks to smooth things out.
    Brakes: Machanicals all around
    Flat Head Ted Floaters
    Front actuator shaft brackets to get everything lined back up
    New cast Drums and pads all around
    Every part of the brakes was cleaned, rebuilt or replaced
    Tires: Front; 5.50-16 on 4.5" wide
    Rear; 7.50-16 on 4.5" wide
    I had planned on do***enting the build but my hard drive crashed and i lost all of my build photos. Here's a couple i have from when i first got it.
  23. BloodyKnuckles
    BloodyKnuckles
    It is soooooooooo nice to see a sedan with fenders in the style you did yours.
    I think your car is absolutley perfect!!!
    Great job!
    ******Knuckles
  24. Lowbuckboz
    Lowbuckboz
    Yeah man, looks awesome! Now I got someone to park next to! Great job! Need some pics with your car and mine....Boz
  25. remdam
    remdam
    from New Jersey
    Thanks Boz, couldn't have done it without you. -Russ
  26. pasadenahotrod
    pasadenahotrod
    from Texas
    USing 32-34 spring perches to get the height was a great idea.
  27. Ryan
    Ryan
    ADMINISTRATOR
    Take pictures... I would really like to see those two together.
  28. LOWFOMOCO
    LOWFOMOCO
    Right on....that things sits perfect!
  29. remdam
    remdam
    from New Jersey
    Ah yes, the elusive 32 perch pins. Rarer than hens teeth and priced to match.
    Thanks to DoctorZ at So-Cal Sacremento for hooking me up with this set. They are unbelievably perfect, appear to have been never used. Oh well, you gotta pay to play.
  30. pasadenahotrod
    pasadenahotrod
    from Texas
    Every 32-34 Car and Pickup has a pair of these in the front axle, and they were available in the aftermarket for many many years as well.
    Most have the "tree" cut off at the shackle boss if they were on a car converted to airplane shocks and hydraulic brakes, just the upper limb if converted to hydraulics but running stock Houdaille lever-arm shocks.
