'64 gto
Discussion in 'The Hokey Ass Message Board' started by Red Dragon Racing, Nov 17, 2009.
  1. Red Dragon Racing
    Red Dragon Racing
    from Indiana
    I have a lead on a '64 GTO Convertible. Any suggestions on how to confirm its the real deal? Anything specific on this car to look for?
    Thanks,
    JW
  2. Kerry67
    Kerry67
    PM Applekrate. He is the Pontiac man !
  3. harrington
    harrington
    from Indiana
    Data plate on the firewall, the model option code for the GTO is 242.
  4. bdk1976
    bdk1976
    Not in '64....
    If there is a 5N on the data plate, that's a good sign, but this may not be present depending on what factory your car was built at.
    The BEST thing to do is spend some $$ and send the VIN to
    www.phs-online.com - they will supply you with the original billing history for your car that will tell you if your car is a 'real' GTO. (actually it only verifies that the submitted VIN belonged to a GTO - you still need to be aware of the possibility of a tag swap during the car's history).
    If you are lucky enough to have the orginal protecto-plate, that would tell you whether it was a real GTO as well.
  5. shemp
    shemp
    Alliance Vendor
    Roll down the rear quarter windows and look at the inside of the quarter panels, between the door and rear wheels. A Le Mans will have many holes from the gills or louvers that have been filled in. Everything else un-bolts, and could be changed. The final word would be PHS.
  6. stuart in mn
    stuart in mn
    As mentioned some of them have a 5N on the data plate but that only applies to cars built at certain plants - I don't recall which ones. If you need proof quickly, PHS will fax the information for a little extra cash.
  7. Squablow
    Squablow
    My Dad did this, with the fax so he didn't have to wait to check on the legitimacy of a GTO. It's well worth the money since it's fairly easy to fake one and Pontiac Historical Society paperwork isn't that expensive. You can't necessarily tell from the VIN or data tag.
    Don't risk paying real GTO money for a clone to save the $50 it costs to check it out.
  8. hellonwheels
    hellonwheels
    from Bastrop
    There were 4 plants that produced the Lemans. Only two produced Lemans with the GTO package. GTO was not an actual model until the 66 year. The 5N code denotes the Fremont or Kansas City plants where the 64 and 65 GTO's were made.
    The ONLY way to know for sure is through PHS. You should definitely spend the money to find out about what you are buying, doesn't cost that much and it's good insurance. These two model years were cloned often because they weren't an actual "model" and because of the 5N code, at least until PHS came along!!
  9. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Go the P.H.S. route, as '64s are probably the easiest goats to fake.
  10. 296 V8
    296 V8
    from Nor~Cal
    Personally for me it wouldn’t matter if it was born that way (gto) if it’s a good deal. Like the others have said, GTO was a option in 64 and 65. All your doing is adding a option. Id bet the majority of cars at action have had a ton of options added.
    I don’t subscribe to the purist point of view because I don’t buy or build cars as investments. Iv had original and option added GTO’s and loved um all.
    BTW 64 isn’t easy to “fake“. The original parts (hood -4 spoke wheel……….) are hard to find and expensive when you do .
  11. bdk1976
    bdk1976
    More misinformation...
    There were four plants that produced A body pontiacs in 1964 (Baltimore, Kansas City, Pontiac, and Fremont). ALL of them produced GTO-optioned Lemans. ONLY Kansas City and Pontiac used the 5N code to denote the GTO option. Baltimore and Fremont did not use the '5 line' coding system on the data tags.
    There have been do***ented examples (albeit very few) of GTOs built at Pontiac/KC that are missing the 5N but are do***ented GTOs.
  12. draggin'GTO
    draggin'GTO
    A '64 GTO is quite easy to fake, there were no GTO-specific tail lights or grilles like the '65 and later GTOs had. Add the hood and you've got a GTO, good enough for most casual GTO fans.
    It's true that the '64 hoods are hard to come by and are not reproduced, I see them trading these days for between 1K and 2K depending on condition. The 4-spoke wood wheels are '64 GTO and big Pontiac only, but '64 GTOs were not commonly equipped with that wheel since it was an option.
    PHS docs are the only sure way.
  13. derelict
    derelict
    I worked at the Fremont plant in '64 and remember the first GTO to come down the line there. The biggest difference was that the GTOs' had convertible frames for stiffness. I don't know how to check for that but it's a clue...
  14. draggin'GTO
    draggin'GTO
    Well, he's buying a convertible so that's no help.
    I've never heard of any '64 GTOs other than convertibles coming with the fully boxed convertible frames.
    I do know that in the early '70s there was a heavy-duty frame option that put the boxed convertible frame under 2-door A-body hardtops.
    PHS is the only way, before you drop any coin find out for sure. A true GTO has twice the value of a comparable LeMans or Tempest, don't pay 'GTO money' for something that really isn't one.
  15. Jingles
    Jingles
    The '64 GTO was a Tempest-- not a Lemans. I bought mine used on June 11, 1967. I plan to restore it in the near future. I think that the '65s were the first ones that were Lemans GTOs.
  16. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Yes, technically, the GTO option was a $295 option on the Tempest, but they used Lemans taillights and Lemans bucket seats.
  17. draggin'GTO
    draggin'GTO
    The GTO was an option on the Lemans, not the Tempest. The Tempest body was built using a completely different rear tail panel, there's no way to bolt a set of LeMans/GTO tail lights onto a Tempest body.
    Both the GTO and LeMans were upscale models derived from the Tempest line.
    Tempest tail panel and tail light treatment. No cutouts in the rear panel to accept the GTO/LeMans tail lights.
    GTO/LeMans tail light treatment.
    GTO/Lemans rear panel, with no lights installed.
  18. Red Dragon Racing
    Red Dragon Racing
    from Indiana
    Thanks for the input guys. I'll get the #'s next time I see the car and look into the PHS.
  19. zman
    zman
    from Garner, NC
  20. cruzingratiot
    cruzingratiot
    from Detroit MI
  21. southpark
    southpark
    funny thing is this thread stays open, but you put a 53 chevy on an s10 frame and its insta-closed.
  22. twotoejoe
    twotoejoe
    Never heard as much misinformation in such a short time in my life! Thank God most was promptly corrected. One thing that wasn't corrected is that ALL 64 GTO's didn't have a convertible (or boxed) frame. Only if you got a convertible or ordered the heavy duty frame did you get the boxed frame, so don't all of you 64 owners with non boxed frames go crazy thinking your frames have been swapped out.
    Also, 65 are very easy to clone also. As in 64, no different grills or taillights. Just emblems and hood. And now the hood is repoped. So, if you are in the market, be sure to get the phs paperwork if you desire a real car. 66-71 cars can be determined by the vin # having '242' as the first 3 numbers.
  23. CRH
    CRH
    from Utah
    twotoejoe is correct.
