Algon fuel injection, and accessories
Discussion in 'The Hokey Ass Message Board' started by Algon, Feb 25, 2008.
  1. Hi!
    Hi!
    from SoCal
    Depending on what you are willing to put up with, mech. injection is great and easy. Playing with the spool is not a big deal if you know what the motor wants after some kind of running base line.Also changing the gas pedal ratio for tip in. You can run them on the street, but would not suggest it for a tuning beginner. The select a jet is also a necesity if to be driven alot around town. Also they like cam and compresion.
  2. Gotgas
    Gotgas
    from DFW USA
    Thank you for the great resonse Algon!
    I thought this is how all mechanical injection systems worked, with a pill used to restrict flow through the return line. Do Algon systems use a different method to meter fuel volume to the injectors?
  3. Hi!
    Hi!
    from SoCal
    Post up the specs and pics of the drive spud. Br*** is easy enough,maybe.
  4. skunx1964
    skunx1964
    wow, thats amazing :eek:
  5. Gotgas
    Gotgas
    from DFW USA
    Thank you very much for all the replies, that helps a great deal-
  6. toxictom
    toxictom
    here is a pict. of mine....! its for an sbc..! wanna build an 327 for that manifold...love it.:)
    kidcampbell71 and Deuces like this.
  7. toxictom
    toxictom
    i don`t know what it is...! changed it for building a carsontop for an 32 roadster, so i think it was a gooood deal:)
  8. The37Kid
    The37Kid
    Here is mine again with the commom water posts & necks. Soked everything with PB Blaster.
  9. Little Wing
    Little Wing
    from Northeast
    Is a 17A size injector nozzle to big ?
  10. mrimpala
    mrimpala
  11. RichFox
    RichFox
    Hilborn 17A would be to big for a gasoline street motor. Think more like a 6A
  12. el Scotto
    el Scotto
    from Tracy, CA
    kidcampbell71 and chickenshift like this.
  13. RichFox
    RichFox
    If the bike was built in Tracy and Al's shop was in Oakland it's possable that it was a one off injector.
    kidcampbell71 likes this.
  14. Kerry
    Kerry
    This is more of a Hilborn question but I've got 104A Hilborn injector nozzles in my four port. Where do these fit in on your refference chart?
  15. Would you happen to have any pics or info on the Y-block Algon, which evidently makes a twist to line up the injectors rather than stacked as with the Hilborn? Would love to see some more detail. Thanks.
  16. Right you are on the Y-block Algon. I thought they were also stacked, but recently saw a pic that identified the above as Algons and thought maybe I wasn't paying attention. On second look, it also looks like some type of EFI conversion as well. By the way, if Hilborn only sold some small number of Y-block injectors any idea how may Algon may have sold?
  17. Here is a mates early Olds I am painting up for him now with Algon Injection.
  18. Scott Miller
    Scott Miller
    from Tampa, Fla
    An Algon for a flathead of course!
    kidcampbell71, Deuces and Togs. like this.
  19. chickenridgerods
    chickenridgerods
    from DSM, IA
    I'm sure if I were to go digging in my pictures I could find 7 different "large port" 409 intakes. That said, they're still rather uncommon; it's probably safe to say there are less than 100 big and small port versions out there, total. (Maybe even a third of that?) The big ports are certainly less common than the small ports.
    I'm still looking for one that isn't outrageously priced, or a small-port version that hasn't been hacked to fit the large-port heads, though... (send me a PM if you have one!).
  20. 7&7
    7&7
    from Colorado
    Kev I have that same injection and Isky drive on a Olds. I have only seen one other pic of that injection. Thanks for posting. My pump is off the back of the blower. Still think he made some cool looking pieces.
  21. buick320a
    buick320a
    from indiana
    Here is my Olds setup on my CR Dragster, but........I need a return plate that bolts on top of the pump, can anyone supply me with a photo or drawing that I could use to make one.
  22. ironduke1987
    ironduke1987
    sorry i am new to this forum and i may be in the wrong spot but i have a question i just got a 2.5 GM iron duke with algon on it and it has been set up for alcohol and i was just wondering what size main jet (pill) i need to make it ready for gas? thanks greatly appreciated with answers
  23. ironduke1987
    ironduke1987
    sent you a PM algon
  24. We are investigating some ideas on mechanical injection . This thread although Algon based has been very interesting for me in particular. Thanks all. Here are a couple of pics of our early mock ups.
    Don
      57.5 KB
      45.8 KB
    Deuces and kidcampbell71 like this.
  25. It has been a lot of fun. We decided to mock up the idea and go from there. We both worked on OEM systems both mech and elctronic. Mocking it up was fun but you also realize that with a bit more thought it might just acutally work.
    Anyway I have found this thread very educational and it has inspired a couple of metering ideas I had almost forgotten about. (Constant pressure, variable metering related to throttle pos***on etc.)
    for those who dont recognize it, it is a new 5.7 hemi done old school.
  26. Bluefoot
    Bluefoot
    I ran a set of algon's on a big block chey unblown gas drag boat, they ran great,wiss i still had them
  27. flatheadjunk
    flatheadjunk
    from Orange CA
    I think I might have some Algon water necks and a block off plate.
  28. RichFox
    RichFox
    Cool. Very simular to what I have been doing, This is a Banger one finished and building one for a Buick 8
