Help identifying FE Ford block & heads
Discussion in 'The Hokey Ass Message Board' started by jtownnewbe, Nov 19, 2009.
  1. jtownnewbe
    jtownnewbe
    What displacement and year is an FE block 8Z581970.
    Heads on motor are C4AE 60906. Motor has a 4V intake. :eek:
  2. krooser
    krooser
  3. The block number isn't in my book does it have any other numbers on it?
    Can you check the head number 6090 is common but should be followed by a letter
  4. jtownnewbe
    jtownnewbe
    What cubic inch and horsepower?
  5. 6090 is just what Ford put to say "it's a head"
  6. Ford-Man
    Ford-Man
    The heads probably are 6090-G heads...same heads on my 390.
  7. smarg
    smarg
    The only year that had a 4V intake was a 427 in 1968??????
    427 Heads parts-# C4AE-6049-F this could be from any year that had the 427.
  8. 56don
    56don
    Sorry, but FE Ford engines have had 4v intakes every year since they were introduced in 1958.As a matter of fact, the 4v is the most plentiful intake you will find.
    The C4 denotes a 1964 cast date,but the head could have come off of any dispacement that year.Can't tell without the letter after the 6049.
    Never have seen a number like the one posted for the block.
  9. head numbers
    1964-65 352 C4AE, C4AE-G
    1964-65 390 C4AE, C4AE-G
    1964 427 HIGH RISER C4AE-6096-F
    Check the block for other numbers & does the intake have any numbers on it is it aluminum or cast?
  10. jtownnewbe
    jtownnewbe
    The heads are 6090-G same as yours. Looks like what I have is a 1964 Galaxy 4V 300 HP motor. Thanks for the help
  11. I think you mean "Galaxie";). I believe the Z in the first number means 300HP 390 4V.
