4.11 to 3.54 gears
Discussion in 'The Hokey Ass Message Board' started by fatboy tim, Nov 19, 2009.
  1. fatboy tim
    fatboy tim
    from Edinburgh
    Am changing from 4.11's to 3.54's on a 32 axle. Anyone done the same ? Better top end speed ?
  2. Hnstray
    Hnstray
    from Quincy, IL
    Th******ally, yes.........but it's not that simple. Depends on available engine power mostly, vehicle wind resistance, rear wheel/tire diameter and probably a few other factors. What it will do however, as you no doubt know, is reduce engine rpm at normal cruising speeds.
  3. fatboy tim
    fatboy tim
    from Edinburgh
    Thanks, I'll see how it goes.
  4. Buckle
    Buckle
    Why the change in ratio? Just curious?
    Buckle
  5. Captain Chaos
    Captain Chaos
    from Missery
    I did in my 442 , lot more drivable on street and hwy. I've gots plenty of power on reserve though so I cannot say if yours will still be enjoyable to drive around town .
  6. fatboy tim
    fatboy tim
    from Edinburgh
    Runs out of steam at 60!
  7. plym49
    plym49
    from Earth
    I've got a set I bought to upgrade my 32 V8 axle. The car is the one in my ava. 322 Nailhead and Dynaflow with a torque tube. I have not had the time to get into it so I will be interested in seeing how it goes for you.
  8. Buckle
    Buckle
    Oh, got ya.
    Buckle
  9. fatboy tim
    fatboy tim
    from Edinburgh
    Once the axle is back in I'll put a post up.
  10. ibcalaveras
    ibcalaveras
    I did the same , much better on the hiway. plus better gas mileage...
  11. Motorhead Extraordinaire
    Alliance Vendor
    I changed my GTO from a stock 4:33 to 3:73's and wish I had gone to 3:23's instead. If you have a big torque monster consider lower number gears to get a good highway ride, lower your RPM's, and save not only your motor but a few bucks on fuel.
    I do miss the 4:33's they were a LOT of fun.
    Joe
  12. CB_Chief
    CB_Chief
    from Oklahoma
    I run 3.73's with a T-5 behind a 283 and have no complaints. I run about 2K RPM at 70 MPH.
  13. plym49
    plym49
    from Earth
    Super. Please detail the steps to get the new pinion in correctly and also the new drive shaft (length change). Thanks.
