I've just welded up a rusted out valve stem hole on a kelse hayes wire wheel, and know I need to find out what diameter to drill the new valve stem hole? Can anyone help? thanks,Scott
You would be assuming 48 that there are 3 others. And there in lies the rub, its the only one I have.
Ah, but it you are using a standard valve stem, then a lot of other wheels will have the same size hole. Scroll down for valve stem info here: http://www.heeters.com/tires.shtml
