hi mi name is angel and i own a 51 cadi sedan and i want to lower my car but i dont want to put any any airbag system or hydroulic crap so can some one please help me and tell what i can do thank you
Welcome to the board. You might want to go do an intro before someone jumps you about it. To anser your question you can put some lowering block in the back. Your local autoparts store should have what you need. In the front cut a coil or two from the front springs. Just make sure and don't use a torch. Cut them with a saw or cut off wheel.
As 29Nash points out, the search button is your friend on this site. There are probably few subjects that have not been covered even if in passing. Play around with it. No No No, the search button, the search button... .
Just throw a box full of Krispy Kreme donuts in it while you're parked outside your local Curves center. It'll get lowered! Butch/56sedandelivery.
