1936 Ford Pick-Up VIN Number
Discussion in 'The Hokey Ass Message Board' started by losdiablotejano, Nov 30, 2009.
  1. losdiablotejano
    losdiablotejano
    I just bought what I thought was a 1935 Ford Pick-Up but when someone saw a photo of it, they said it was a 1936. Can someone tell me where on the frame I can find the VIN number on a 1936 Ford Pick-up.
  2. If it is not on the firewall it should be engraved on the frame (driver's side) on the top about where the steering box would be.
  3. losdiablotejano
    losdiablotejano
    Thanks for the help. I will start my search there.
  4. Fe26
    Fe26
    Post a pic.
  5. losdiablotejano
    losdiablotejano
    Here is a pic of my socalled 1935 Ford Pick-Up.
  6. sskustomz
    sskustomz
    from bingo,ny
    Well its deff a 36 but i see the tag is gone off the firewall and it looks like someone stubed that thing so the vin is probaly gone
  7. If you have any of the original frame left at about the motor mount area the VIN should be on top of that rail. If it has been replaced with the tube steel for your MII front end, it is probably gone.
  8. Fe26
    Fe26
    You have a '36' cab. the windscreen posts are curved at the place where they meet the cowl, '35' are straight with no curve at the bottom of the post.
    The numbers were stamped on the left hand side ch***is rail in three places, front (as mentioned) under the cab and rear (under the bed).
    Good luck.
  9. Thorkle Rod
    Thorkle Rod
    Hey welcome and cool start to a project, I sent you a PM also (Personel Message)
    My 36 frame is also marked on top of the frame rail about where the frame kicks up for the rear end.
  10. FalconMan
    FalconMan
    from Minnesota
    The VIN is also on two other spots on the frame, I believe on the top side of the drivers side, above the rear wheel, and the other I forget.
  11. FalconMan
    FalconMan
    from Minnesota
    oh yeah.... it should start as a 18-********, ***uming the cars are like the trucks.
  12. Von Richthofen
    Von Richthofen
    heres the diference the body line
    on the 35 here blue truck i had the pic from
    another site the one in primer is 36 and a frame
    pic where the # is on the frame hope it helps
    i went thru the same thing on mine its a 36
