What's a fair price for a mustang II crossmember install
Discussion in 'The Hokey Ass Message Board' started by RatPin, Nov 18, 2009.
  1. RatPin
    RatPin
    I'm considering installing a Heidt's MII IFS in a '54 pickup. I have the truck all stripped down to the frame, motor out. What would you consider a fair price for a shop to install the complete IFS suspension minus transfering the steering over.
    A local shop quoted me $400 in labor without seeing the truck. Is this about right?
  2. hotrod-Linkin
    hotrod-Linkin
    i would't do it any cheaper.
  3. texoutsider
    texoutsider
    from Frisco, Tx
    Ditto on that.......more like a grand at least but with it steering out my door......
    Mark
  4. Antny
    Antny
    from Noo Yawk
    $400 sounds very reasonable. 8 hours of work at $50/hr? Sounds about right to me. I think it took me 16 hours to install mine, which included about 8 hours of head scratchin. :D
  5. 35mastr
    35mastr
    from Norcal
    Me either. 400.00 is not all that expensive if the shop is a legite one.
    Steering is pretty simple after that.
  6. coolstuff
    coolstuff
    from Bettendorf
    that sounds GREAT to me
  7. I would have happily paid someone $400 to put mine in...and that was over 10 years ago...
  8. Hotrod1932
    Hotrod1932
    from Oregon
    Boy I would go for it as long as they know what they"re doing. Get it in paper. Took me about 10 hrs. Good luck
  9. Make DAMN sure the underside of the crossmember is plated when they are done. These crossmembers have a tendency to develop stress fracture at the folds on the underside, leading to serious failure.
    The plates should be of the same material, and should cover the whole area from 'A' arm pivot back to frame.
    Please also consider using the original Ford design, with the trailing arm and rubber biscuits. This nearly eliminates any dangerous stress in the crossmember.
    There was a thread on this (and on MY car) back in 2002, but it's gone now.
    Cosmo
  10. If it is just a matter of installing a pre-fit crossmember (like a heidts) it should only take 3 to 4 hours to box 16'' of the frame and weld in the crossmember. If it needs to be trimed to fit and all the suspension bolted on then it becomes about a days work.$400.00 doesnt sound that unreasonable! Just my 2 cents!
    Grant www.schwartzwelding.com
  11. newfalconowner
    newfalconowner
    from NS Canada
    took me almost 2hrs to trim,weld mine up together (welder series crossmember) and tack it all in place. 400 sounds like a good price for half a days work.. good luck
  12. 37FABRICATION
    37FABRICATION
    $400 is cheap. If you're confident the shop does quality work, that's a very good price. Make sure the frame will be boxed and crossmembers installed properly and welded completely. No 'one sided' or tacked pieces. Post pics...
  13. gimpyshotrods
    gimpyshotrods
    Uh, get that in writing, and then get on it. I just did a TCI MII in a '51 Chevy for $1250, just labor, no steering column or p/s pump hookup. I did chop the box off of the end of the column, and put on a bearing and and coupler to get him on his way. In-n-out, same day.
    I am always willing to negotiate, but if they just say "ok" when I quote a random price for fun, what am I supposed to do?
  14. RatPin
    RatPin
    Thanks guys! Sounds like everybody agrees then that it's a good deal. The shop is a full blown custom frame shop and I've been talking to the owner about my project, so hopefully it's not the old bait and switch routine. I'm going to set up a time I can drag the old girl over there and talk with them about it. I do plan on getting it in writting before hand. I know how things tend to take longer than expected.
  15. RatPin
    RatPin
    Well I followed up with the quote and it turns out the $400 was just to weld in the crossmember and box that area of the frame. it was not to install any components of the IFS. Now how does the quote sound? I have already cleaned the area to bare metal.
  16. poboyross
    poboyross
    from West TN
    Based on what I've tried to get quoted out here in Jersey, that's a STEAL! I went to get a quote to do some tack welds (6 x 1inch long welds) to my shock mounts....place quoted me 360 Bucks!!!!!! I grabbed my junk and walked out.....so much for good deals during a recession!!!
  17. hotrod-Linkin
    hotrod-Linkin
    this is making me dizzy. the other components aren't that tough to install..can you and some friends do it???
  18. zman
    zman
    from Garner, NC
    Sounds about what I would charge. I wouldn't be upset with the price.
  19. mj40's
    mj40's
    We have a shop locally that charges a base rate of $70 per hour. What they are not telling you is that is X every person that is working on it in that hour. Ouch!!! It pays to ask questions.
  20. puschrod
    puschrod
    The price sounds pretty good to me. You're saying they are a high end, custom shop so, I'm sure their work is worth the price. I guess I don't understand the question at this point. If it's too much money, why don't you step up and try doing it yourself. If you haven't done this kind of work before, it always "looks" easy in the magazine articles. Spend the money with a good, quality shop, for a reasonable price and you and your ride will be happy when you hit the road.
  21. tomslik
    tomslik
    do they know enough to put it ahead of the original about a 1.5"?i don't remember for sure how much forward so don't quote me
    it's cause the wheels in the fenders were too far back for my taste and when you lower it, it get's even worse
    400 bucks ain't bad for just the install...
    can't say i've put a MII in a f100 but i did a pacer in one....
  22. gnichols
    gnichols
    from Tampa, FL
    Be sure they know what they are doing, regardless of the price. A buddy of mine got a friend to install one... it ended up at the wrong height, at the wrong angle, etc. Never was right.. he sold his project in frustration because of it. Not a LOL. The new owner is tearing it all out and starting over. Gary
