caddy 390 valve question
Discussion in 'The Hokey Ass Message Board' started by dirthawker1313, Nov 30, 2009.
  1. dirthawker1313
    dirthawker1313
    can anybody tell me what the valves on a 1962 caddy 390 should be adjusted to..i found the firing order but i cant seem to find the valve specs. thanks
  2. 6deucecaddy
    6deucecaddy
    Are they stock? Cause stock aren't adstustable. If not stock what are you using?
  3. dirthawker1313
    dirthawker1313
    i believe there stock. my buddy just got the car and the number 6 cyl is a little low on compression.
  4. puschrod
    puschrod
    The 60 caddy with 390 I had didn't have adjustable rockers. Not stock?
