truck dies when put into gear
Discussion in 'The Hokey Ass Message Board' started by bigroy, Dec 2, 2009.
  1. bigroy
    bigroy
    76 dodge power with a 440 and 727 automatic trans.dies when i put it into gear but idles and revs fine if its in park or neutral.
  2. binderfan
    binderfan
    from bay area
    I think the problem might be that it is about 12 years too new.
    For this site.
    :D
  3. Mr48chev
    Low idle speed or timing being off would be my thoughts. And you did say that the engine was going in your hotrod one of these days didn't you??
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
  4. Frosty21
    Frosty21
    from KY
    Possibly a bad torque converter as well.
  5. MarkzRodz
    MarkzRodz
  6. I have to agree with MarkzRodz. Its ****ing vacuum somewhere. Either a bad center head gasket, or a hole in the power brake vacuum diaphragm are two places to start looking.
  7. bigroy
    bigroy
    no the truck belongs to my father
  8. 57JoeFoMoPar
    57JoeFoMoPar
    Could be a vacuum leak, or it could be timing off really far. Balancer spun on my 383. When I set TDC by the balancer and started it, it started and idled fine. But as soon as I put it in gear, it would die. Turns out it was 20 degrees retarded. Set TDC by feeling #1 with a screwdriver, remarked the balancer, reset timing and have driven it with no issues since
  9. ThePuck
    ThePuck
    from Ottawa
    Not enough base timing, or you have your vacuum can plugged into the wrong port on the carb.
  10. MengesTwinCustoms
    MengesTwinCustoms
    plug a vacuum gauge up and time it with that. you will also see if it has a leak or not. advance it to be the highest vacuum level then drop it 1 inch of Hg and should be good.
  11. fordcragar
    fordcragar
    from Yakima WA.
    It's good that you are trying to fix the problem before removing it from the donor vehicle; otherwise this would be entirely off-topic.:rolleyes:
  12. 42hotrod
    42hotrod
    from S.E. Idaho
    I've got it!!!
    Don't put it in gear and it won't die!! :D
  13. roddinron
    roddinron
    Is it the holiday spirit already, or is the HAMB getting soft?:confused:
  14. bigroy
    bigroy
    fixed it. was a bad fuel filter
  15. Ruiner
    Ruiner
    Good job, now never mention it ever again...
