what is the difference between 28-29 and 30-31 model a deck lid
Discussion in 'The Hokey Ass Message Board' started by FlatBlackRat, Dec 3, 2009.
  1. FlatBlackRat
    FlatBlackRat
    i have googled my **** off and still cant find what is the difference between the ford model a deck lid from the 28-29 and 30-31 i have a 30-31 coupe roadster and i need a deck lid but i was wandering if i can use a 28-29 or not so any info would really help me out thank you
  2. lowbiz
    lowbiz
    99% sure there are no differences between the two.
  3. pitman
    pitman
    Brookville lists two different part no.s
    I seem to recall that the curve radius may be different.
    See if any searches help.
  4. vert1940
    vert1940
    rumble lids are different in the latch area...not sure about a trunk though
  5. Justin B
    Justin B
    28-29 have a raised area by the rumble lid latch, on the inner skin. there's a recess in the trunk rail to accommodate this. i've heard there might be a little difference in the contour but have swapped year to year and they seem to line up fine, given just about every original decklid needs some tweaking. a 30-31 will bolt right up to a 28-29 but to use a 28-29 on a 30-31 you have to either cut a notch in the trunk rail or remove the raised area on the decklid by the rumble latch.
  6. Stovebolt
    Stovebolt
    I've got a 31 deck lid on my 29, but its plastic - fitted up with a little work, mainly because it wasn't perfect on the inside, and converted from ****ie seat to trunk.
    The guy I got it off fitted a lourved 29 deck lid to his 31, and it fitted fine
  7. FlatBlackRat
    FlatBlackRat
    thank all of you that really helps me out i have to pretty much custom do everything already so i just need a deck lid now you guys rock
