I'm not sure but I needed to ask. I think my rear end is a Elco, Chevelle 10 bolt, But I don't remember seeing one with Bumps. I was going to cut them off and install ladder bars for a four link set up. What do you think? This is on my 55 2nd series panel truck. I call the Moonshine Panel. I want to lower it 3" front and rear.
you mean the upper control arm bushings? you can cut them off or leave them, they were on lotsa GM cars in the 60s-80s
Is it uncomfortable to sit? If not, just wear loose fittting pants and no one will know. Surgery would cost a small fortune.
Thnks Jim. I think cutting them off is the best thing with the lowering job I dont want them to hit the bottom of the OG wood floor
