Projects Cost of your next step
Discussion in 'The Hokey Ass Message Board' started by The37Kid, Dec 4, 2009.
  1. The37Kid
    The37Kid
    Can't make any progress unless you spend money? I need to refill or start a new tank rental so I can weld. Need around $300., what is ground your project to a halt?:confused:
  2. need louvers ?
    need louvers ?
    The economy in general!
  3. 5window
    5window
    Paint-and economic fear. It's not that I don't have the money now, it's whether I can spend it now and have more later.
  4. DEEPNHOCK
    DEEPNHOCK
    32 yards of cement:eek:
  5. PhilJohnson
    PhilJohnson
    Lack of a garage.
  6. ocool25
    ocool25
    from Indiana
    Ditto!
  7. barslazyr
    barslazyr
    x2 I can use the one at work after I fix everything there that needs it.
  8. 19Fordy
    19Fordy
    Cheaper to buy your own tanks in the long run.... if you can.
  9. chevy57dude
    chevy57dude
    3K worth of bodywork and paint yet to pay for. Then gl***, chrome, interior, weatherstripping......AARRRGH!
  10. That and some serious debt draining all my money off. The way I see it, pay it off as quick as I can them all that money is free to spend on my car.
    Doc.
  11. poboyross
    poboyross
    from West TN
    Like others...I am Garage-challenged. The other culprit is time.....to many responsibilities and fires to put out.
  12. vernmotor
    vernmotor
    from ohio
    Transmission parts 700.00 would be good...
  13. Larry T
    Larry T
    Probably about 1500.00 to finsh setting up the narrowed 12 bolt rearend for my Anglia. Kinda hard to cut corners on racecar drivetrains. I think it's still gonna be cheaper than a 9" Ford.
    Larry T
  14. Ayers Garage
    Ayers Garage
    400 dollars or so for building my exhaust. Need Brockman mufflers, mandrel bends, straight pipe, hangers, and tips. Once I have all of that I can do the building, but paying for the parts is likely happen after the new year at this rate.
  15. Ghost28
    Ghost28
    The cost of my next step is all the steering connections from the column down to the vega box for my project. Once there installed I can blow it all apart and do all the finals on the frame, and under body welding. There is lots to do before spending any serious money which I don't have...John
  16. hemi
    hemi
    Christmas and kids... I need about $300 for a steering box swap.
  17. Bodywork consumables...
    I have a IROC 12:1 605 box and pump to sell to start me off.
  18. Domn8r
    Domn8r
    from Helena, MO
    I need money for interior .... recent lay-offs have depleted my resoources
  19. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    I am trying to drum up around 5-6k to fullfill my parts list for the next DragCar project...been working overtime and now looking into selling some stuff off....I may unload the Chevy 409 thats bolted in the Divco..and maybe the Divco itself..had thoughts of selling my Model A Pickup as a roller...but really..who is going to fit into it.....I am lucky I have the overtime available.........sometimes I wish my only hobby was collecting rocks !.........This HotRod hobby is driving me mad...I would sell myself on the street corner for parts money, but I am not too marketable ha ha ha .......I just cannot stop myself or my mind...and have no grasp on moderation.....Littleman
  20. chris55
    chris55
    Need around 550. for tans. work, 250. for suspension parts, 400. for fenderwell headers, and the list goes on and on.
  21. About $1500 to sand blast and powder coat my entire car inside and out, frame, suspension and drive train. Yea.
  22. Need money to build engine for my Willys project. Been trying to sell my roadster pickup but no luck yet. Need to buy a new sfi approved flywheel, pressure plate so I can get the bottom end balanced. Hundreds of dollars that just aren't there.Also need cam and kit, rings, bearings etc. Need to buy a pair of aftermarket axles with bearings and studs. Another $400 or so. There are still some things I can do without spending money so I haven't ground to a complete stop yet. Gotta sell that RPU!
  23. zimm
    zimm
    from iowa
    this is depressing
  24. Hubbcat
    Hubbcat
    from Sweden
    i´m with u zimm.
  25. Kirk Hanning
    Kirk Hanning
    It's pretty reduntant.....As soon as you have collected up enough $$$$ for the next "big purchase". There's too many more to follow.
    It hasn't made me stop yet.....
  26. Hubbcat
    Hubbcat
    from Sweden
    Don´t even want to think about it.new bought 66chevy II need ewery thing.
    sold the 51 on the avatar,boy do i regret that!
    the money dont even last to do the brakes,
  27. swade41
    swade41
    from Buffalo,NY
    I need about a hundred grand to pay off my house then I'd have extra money for the projects. I read where some guys don't have garages and here I got a big one but can't afford to do anything in it. Hell I'd love to be able to afford the gas bill to turn the heat on out there to just be able to get something done.
  28. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Many years ago around christmas time.I left my backgarage door unlocked.And of course I was robbed.Worst thing was they stole my 125,000 Btu torpedo heater.Stopped progress for 2 months,The fires I lit on the garage floor didn't work ,I was pissed .Since then I installed a 16 foot garage door ,Sad but shortened garage down 12 x20 for family room .Its still23x20 Only one way in and one way out and torpedo heater is hard piped in to outside vent.If I ever have a problem I've got to run through the wall with 2 foot centers .
  29. Retro Jim
    Retro Jim
    I need a new water pump , spark plugs , plug wires for the Ford 302 engine I am rebuilding . Also need a new clutch , pressure plate , throw out bearing , cable and mandrel . Will then see if I will need a drive shaft , but can count on needing one . So about $600+ . Then I go for the body work which is mostly sanding and paint .
    RetroJim
  30. Thorkle Rod
    Thorkle Rod
    time and money no!, no!, no!, that's not it, it's and money and time or was it time and money, ................it's one of those.
    Need some Coil Overs and shock mounts, Flywheel, PP clutch blah blah this IS DEPRESSING!!
