What the @#$% is an RV CAM anyway??
Discussion in 'The Hokey Ass Message Board' started by allengator, Dec 7, 2009.
  1. allengator
    allengator
    from Keller, TX
    All my life I have heard of people brag about putting in an RV CAM...
    What really is an RV cam??
    I have never seen one for sale....
    Was it a cam meant for an RV engine that people used because custom performance cams werent available...???? OR???
    (I tried to search but could not find anything!)
    Thanks in advance!
  2. zman
    zman
    from Garner, NC
    RV cams are designed more for low-end torque than high-end horsepower.
  3. Mr48chev
    I think that they are referring to a grind that is aimed more for low end torque and pulling power rather then high end rpm.
    Lots of the off road guys want a lot of low end grunt but aren't all that excited about having an engine that will wind to eight grand.
    1biggeorge likes this.
  4. Da Tinman
    Da Tinman
    typically an rv grind cam is a little bigger than stock, and will improve your lower end torque and mid range power, should get better mileage too.
    "RV Grind" is a generic term for any cam that does the above.
    Moondog13 and Boneyard51 like this.
  5. allengator
    allengator
    from Keller, TX
    cool! Thanks guys....
    I love this place!
  6. Mark Hinds
    Mark Hinds
    from pomona ca
    You can ask the same question for a 3/4 race cam. Is that like a 4-7 swap cam
  7. squirrel
    in the old old days...there were stock cams, semi race cams, 3/4 race cams, and full race cams. This terminology is meaningless today.
  8. millersgarage
    millersgarage
    I always thought a 3/4 cam was from a V6
    :p
  9. Licensed to kill
    Licensed to kill
    from Alberta
    Awsome :D:D:D
    Boneyard51 likes this.
  10. pasadenahotrod
    pasadenahotrod
    from Texas
    THAT is funny!
  11. allengator
    allengator
    from Keller, TX
    greatness
  12. squirrel
    It was funny about 30 years ago :)
    btw, RV means a cam is almost stock, it's one step up.
    olscrounger and Boneyard51 like this.
  13. bobss396
    bobss396
    I'm sure the grind is still in cam catalogs, just has a different name. I had a couple of RV hydraulics that were on the lumpy side but still good for a daily driver.
    Bob
  14. Hemi Joel
    Hemi Joel
    from Minnesota
    I had a ford boom truck that weighed 15 ton with a 391 gas motor. Even with 20 gears available, that thing was so slow it was a hazard. I put an RV cam in it. It had slightly more duration than stock, and quite a bit more lift, Also did dual exhaust with free flowing mufflers + quickened the advance curve. It sounded good, with a slightly choppy idle, but was still incredibly slow.
  15. novadude
    novadude
    With SBCs, it seems like "RV cam" usually refers to the generic 204/214 @ 0.050, .420"/.442", 112 LSA grind.
  16. low budget
    low budget
    from Central Ky
    I never heard it before, but then again they say us Ky boys are kind of behind the times on things:D
  17. RV cams come from the same era that brought us the stupendously bad Edelbrock SP2P intake manifold.
    So can someone explain the Isky 5 cycle cam then?
    lemondana and olscrounger like this.
  18. wbrw32
    wbrw32
  19. Ebbsspeed
    Ebbsspeed
    Basically it's a very long overlap cam that was used to help cool the piston and valves by letting a lot of the cool charge blow through the combustion chamber while both valves were open. Intake, Compression, Combustion, Exhaust, Cool. 5 Cycles. It worked OK on blower motors, not sure how effective it would be on a normally aspirated engine.
  20. jlfutch
    jlfutch
    I always knew the "RV" cam was for low end torque and was told that the "RV" stood for Recreational Vehicle. Hence the cam was for towing and hauling. But what do I know?
    seb fontana and INVISIBLEKID like this.
  21. Thanks! I have always wondered about that.
  22. I agree! ;) I don't know how many times someone has asked me if the 855 ***mins crank I'm working on was out of a VW, same sort of deal, never gets old. :p
  23. squirrel
    that's exactly what it means.
  24. I figured an RV cam was an excuse to charge you $10 more than the stock cam.
  25. Screamin' Metal
    Screamin' Metal
    from Oklahoma
    Hey Squirrel....I wonder if we ought to tell him about those 'Thread Stretchers' they've got at some machine shops and hardware stores to make those special bolts fit????? Naw....probably too easy....
  26. Nads
    Nads
    from Hypocrisy
    Often times I hear people saying "it has a cam" about their hopped up engines, to which I reply, "Don't they all, unless they're rotaries or 2 strokes?"
  27. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Kind of like a "stall converter"? "Hey, it's got a stall converter in it". Well, guess what.....if it didn't stall at some point, it wouldn't be a torque converter!
  28. HEATHEN
    HEATHEN
    from SIDNEY, NY
    But, most importantly, it gave Iskenderian an excuse to have that cool decal with the clown riding a unicycle.
  29. My 454" Chevelle's engine was put together with an RV cam.
    It has gobs of low end torque, lotsa oompf but it falls flat after 5000 RPM.
    That cam wasn't my choice, it was already plugged into the block when I purchased the car in the early 90's.
    It is trouble free and keeps me away from punishment at the red line.
    I does have lots of vacuum at idle and a tiny bit of cammy idle to it.
    I live with it!
  30. Shifty Shifterton
    Shifty Shifterton
    Wanna know why an RV would need a different cam?
    They have higher cruise RPMs than cars. Typically they're so overworked that they're geared to highway cruise at 3000 or higher.
    "stock" cams are targeted to 2200ish cruising in most cars and light trucks. Scale up the specs so the sweet spot is around 3000, you have yourself an RV cam. Make sense?
