Flat U-Bolts and Vintage Bolt Source
Discussion in 'The Hokey Ass Message Board' started by Little Wing, Dec 7, 2009.
  1. Little Wing
    Little Wing
    from Northeast
    Is the a special name for U- Bolts that have the flat surface on the inside ?
    Also is there a good source for Older Nuts and Bolts ?? Been looking for good old fashion Machine Bolts ,,cheap junk hex seems to be all anyplace carries.
  2. landseaandair
    landseaandair
    from phoenix
  3. Bobbyhotrods
    Bobbyhotrods
    If you can find a spring shop where there's still a blacksmith they make their own, and certainly could flatten the inside radius. That said, the only spring shop with a blacksmith left in New England to my knowledge is Palmer Spring in Providence, RI.
  4. burl
    burl
    from Minnesota
    Try St.Louis spring,had them make up some main leafs for me.The seemed to have or know about all things related to springs,u-bolts.
  5. Bruce Lancaster
    Bruce Lancaster
    Try Nacewicz bolts...you can find a crude webpage to order a catalog. His selection of early Ford bolts gives you a pretty good selection of nice looking stuff that does not scream "Home Depot!"
