My first Plymouth... 52 Cranbrook
Discussion in 'The Hokey Ass Message Board' started by screwshiney, Dec 3, 2009.
  1. screwshiney
    screwshiney
    i've wanted an old car for a long time and when i found this on craigslist i couldn't p*** it up. it's a 52 cranbrook w/a 230 flat head 6 w/ a 3spd. only down side is no ***le, however i have already found one. i know like i need another project.
    it actually runs and drives pretty damn good. the guy bought it to rat it out but lost interest. he replaced the rear brake line, all the shocks, new plugs and points and a new battery. it starts and runs perfectly.
    it needs the usual rust/rot repair but actually less then my 68 k20. i'm going to see if i can pull the driver door rather then replace it, i'm really partial to the matching patina.
    here are a few pics. plans are to get it road worthy, clean up the interior a bit and just drive it as is.
    more updated pics to come.
  2. sinks88
    sinks88
    sweet, looks like you got a bit of work ahead of ya!
    nice to see some more 4 doors
  3. screwshiney
    screwshiney
    i did manage to fix a few things. i worked out a few of the major dents, pulled the driver rocker out from looking like a >, put a "new" exhaust on, fixed the bent *** steering arm that was jacked up by a forklift or something, damn thing was bent in a 45*.
    on her way to the shop
    BIG dent
    much much smaller dents
    orig seat!
    worst parts of the floor
    cool radio box i found under the dash
  4. bobss396
    bobss396
    Ooooffff... looks almost like a Flintstone mobile. Deffo a cool car but more rust than I'd like to deal with. But parts are around and they're pretty easy to work on.
    Bob
  5. 34FordConv
    34FordConv
    It can be fixed ... That'll make a cool daily driver
  6. screwshiney
    screwshiney
    hey for $300 bucks i'm not *****ing :)
    ha bob look at the floor in my 68 and i paid $1000 for it. i think i'm up for the challenge.
    but that was an easy fix...
  7. screwshiney
    screwshiney
    and the new junk pile exhaust. got it up as tight as i coudl so when i lower nothing hits.
  8. screwshiney
    screwshiney
    i think i'll call it frankenfloor. wow does weling thin rusty metal ****. almost done though. just a few more small patches and i need to rebuild the bottom of the panel that goes around the pedals.
  9. Kerry67
    Kerry67
    If you got that for $300 and it runs and drives, you did pretty good even though there is some rust. Well worth that price.....
  10. 29nash
    29nash
    from colorado
    I like your exhaust.
    What's with the muffler? ha, ha, just kidding.:D
  11. screwshiney
    screwshiney
    ha i put it on there then my girl tells me it's too quiet... she wants it loud.
    yea i figured it was a god deal too. hey it's only metal. so far i've got about $450 into the car including buying it. but it still need tires. i did find a killer deal on some new www, 5 for $250!
  12. I dig it. Try to resist the temptation to over do it...
  13. missysdad1
    missysdad1
    Looking very, very good! Glad to see you're not afraid to tackle the rust work yourself. Keep up the good work!
  14. pasadenahotrod
    pasadenahotrod
    from Texas
    That exhaust wouldn't p*** here. It has to be behind the p***enger compartment.
  15. 41 C28
    41 C28
    Looks like you got a good deal nothing that a little sheet metal and welding won't take care . Check NAPA for mechanical parts.
  16. 50specialdeluxe
    50specialdeluxe
    I'm going to be following this thread closely as I got a 50 Special Deluxe almost identical to yours...including the swiss cheese floor. I don't have the resources you have in the way of welding but I'm going to learn and get her going. I have no plans to do anything except drop it a little, straighten out the exhaust and brakes, patch the panels, lose the bias plys for www's and drive the hell out of it!
    If you need parts I may be able to help depending on what you need as I got a ton of extra parts when I bought mine. Good luck and keep posting pix!
  17. plym_46
    plym_46
    from central NY
    The stock engine would be a 218, Plymouth didn't get 230 until late 54. What it the engine mumber??? Is on the block just above the generator.
  18. AZ29
    AZ29
    from Arizona
  19. RATFINKFOREVER
    RATFINKFOREVER
    from Canada Eh
    Gotta love the old Mopars.
  20. Lazer5000
    Lazer5000
    I'm pretty sure that's a '51. I'm no expert, but I had a '51 and it looked exactly like that.
  21. Lazer5000
    Lazer5000
    P.s. I think the six was 217.8 c.i..
  22. Positive Pete
    Positive Pete
    from Florida
    Sweet find and should be a fun build. One piece of advice. Go ahead and rebuild the Master Cylinder while you have the floor cut up. It'll keep you from having to lay on the ground to get it out. Also reuse or recreate the access hole for the master if you haven't already done it.
  23. rjgideon
    rjgideon
    51, 52, whatever it takes. They are the same body style, same grille, just a subtle difference with the rear tag light.
  24. rhd
    rhd
    from austin tx
    yep thats a 51 i have the same car but a 2 door, i think every cranbrooks floor looks like that......im starting to think they came from the factory like that:mad: let me know if you have any questions or need any parts for it im into mine 2 years now
  25. screwshiney
    screwshiney
    excellent thanks guys.
    i've looked at tons of pics and the 51-52s are so very close to the same. i'm just starting to read up on these things, the plymouth stuff is all new to me. never had a car where you have reverse thread on only one side of the car haha.
    and pete i did actually cut the notch in the floor where the ms is. i will have to look into where to find parts for it. thanks for the heads up.
    i did find a factory turn signal switch in the junkyard tho that i will be putting in when i rewire everything.
    i am in need of a few things. i'm looking for a set of tail light lenses and also front marker lenses. also a dash clock if anyone has that haha.
  26. 29nash
    29nash
    from colorado
    I have a special place in my heart for the '52 Plymouth. In my second year of HS my dad bought one new. Grey cloth interior, Maroon paint. Every time one of us drove it, he inspected it for 'pecker tracks'.:eek:
  27. :eek:
  28. Love those '49-'54 Mopars! You've done great work so far. Don't forget to check Blue Skies Plymouth for inspiration! He's here on the HAMB.
  29. screwshiney
    screwshiney
    yea i was looking at some of his stuff. super clean but he is in a different ballpark with that thing lol
  30. Daves 48 Special
    Daves 48 Special
    Hey pasadena hot rod ,Does that aply for lakepipes also ?
