Help . . . .
Discussion in 'The Hokey Ass Message Board' started by Chris Melzo, Dec 8, 2009.
  1. Chris Melzo
    Chris Melzo
    from Reno, NV
    The 350 in the 51 has trouble idling in drive when at a stop. Ive had mixed responses from people here ( in Reno ) that Ive asked. Its got a pretty lumpy cam, and the stall on the t.c. is 1800. So a couple people said bigger stall. But most said its a vacuum issue. Is the cam robbing the engine of vacuum? Or do I most likely have a leak? All the vacuum lines on the carb seem to be good. They're all new. How do I check to see if the intake is leaking? At the moment I'm popping it in nuetral as I'm rolling to a stop:(. At first I just turned up the idle, but now when I put it in park or nuetral, it idles too high.:mad: What do I do?
  2. 416Ford
    416Ford
    Put a CLEAN rag over the carb and see if it runs better. If so you have a vacuum leak.
  3. Easy test for leaking manifold is to spray all the vacuum lines and exposed gasket surfaces with starting fluid. If there is a leak the Idle will jump up, repeat to confirm.
    NOTE: have a fire extinguisher handy! you just may find some bad plug wires doing this test.
  4. Chris Melzo
    Chris Melzo
    from Reno, NV
    Thanks guys, wont be driving it today as we got over a foot of snow here in Reno, but I'll definitely check it out.;)
  5. robt500
    robt500
    from Lex, KY
    jrblack30 filled you in on the air leak check. I had a similar issue with a small block ford that turned out to be condensation in the cap. At lights/idle it would miss something awful and occasionally sputter and die but if I threw it in neutral and gave it some rpm this miss would go away. Ran down the road fine. A complete tune up and I could see the moisture. Didn't do it after that.
