Im in the process of finishing up my garage . Just wondering if anyone had some good pictures of Metal work Benches or Tubing / Sheetmetal storage Holders. Im trying to get the most out of the dead corner space and wall's . Thanks Matt
I know this looks kinda "over the top" but I'd rather do my work well and only once. The bench top is 1/2 inch steel . the framework beneath it is 2 inch angle iron on two inch legs. Each leg has a nut welded to the bottom, and a bolt in that to allow adjustment to keep the whole thing perfectly level. Its 20 feet long. I hammer on it weld on it, and weld stops to it as needed for fabrication work. It was kinda expensive, but well worth the time and money.
