36 Ford 5 window frame question
Discussion in 'The Hokey Ass Message Board' started by MFChassisworks, Dec 9, 2009.
  1. Is a 1936 Ford 5 window frame the same as a 33/34? If not what are the differences? Is that a frame that is normally used for swaps or just the rails? The FNG thanks you.
    Andrew
  2. sawzall
    sawzall
    1935 - 1940 frames are basically the same.. 33 and 34 are by themselves
    so NO.. a 33/ 34 frame isnt going to work (nor is it normally used)
  3. Can you use the rails for something else? Modified??
  4. sawzall
    sawzall
    yes.. you can use 34 rails.. under a 34 :)
    if your gonna do a 36 you need a 35 - 40 frame..
  5. spiffy1937
    spiffy1937
    from Florida
  6. Awesome link,PERFECT! thanks man!
