Projects The NEW PROJECT (here goes the next 2 years of my life)
Discussion in 'The Hokey Ass Message Board' started by DirtyWoody28, Dec 8, 2009.
  1. FlamedChevy
    FlamedChevy
    Don't chop the pickup....
  2. cafekid
    cafekid
    x2 besides i put a built v8-60(129hp) in a 31 closed cab i built for a customer and within a month he was having me pull it out and i dropped in a warmed over 8ba. the poor thing wouldnt get outta its own way if you stuck a cattle prod up its ***.
  3. JimSwann
    JimSwann
    I didn't chop mine because the cab was nearly perfect, but they look good with a light chop.
    Im currently swapping the tired 302 for a rebuilt 302 and rebuilding the toploader 4 speed. I scored a T-176 shift tower from craigslist and plan on installing it in the transmission. The shifter was way too far back and never did look right. The Jeep shifter should come thru the tunnel at nearly the stock location.
  4. DirtyWoody28
    DirtyWoody28
    do they make an adapter to bolt a y-block to a flathead ******? Or does anyone make an open drive adapter for a 36-39 banjo
  5. Razorshotrods
    Razorshotrods
    from Phoenix
  6. A.P. Photography
    A.P. Photography
    Glad you decided on no chop. Gonna look killer.
  7. bjinx
    bjinx
    No chop, shiny paint.
    Although the 4" chop looks goog also.
    What to do What to do!
  8. 34Chrysler
    34Chrysler
    NO CHOP, low slung, wide fives (without caps) and Y block powered are my votes..
  9. RodStRace
    RodStRace
    For a tow vehicle, get as tough as you can on the driveline, suspension and brakes.
    Build for the use, then make it pretty. That thing looks like it's got pretty in it's DNA, so no problem there.
  10. classicmike
    classicmike
    Noooo, don't chop it. How many are left? Leave it original and lower it
  11. DirtyWoody28
    DirtyWoody28
    Heres the begining, the 37 ford whose frame is getting sacrificed for the truck. Keeping the wide 5s, the V8 60 and axles for the T or A. The body is for sale if anyone is interested. If not it will be something someday. Got more pics coming of the frame.
  12. DirtyWoody28
    DirtyWoody28
    The frame wasn't as solid as I thought so I had to repair the P***enger side rail.
  13. DirtyWoody28
    DirtyWoody28
    I kept the x member in the frame to prevent warpage as much as possible
  14. DirtyWoody28
    DirtyWoody28
    Now I get to sand blast for the next two weeks and hopefully I don't kill myself doing it LOL!!!!
  15. Lee_Ford
    Lee_Ford
    Nice truck...
    A quick tip on PhotoShopping or PhotoChopping. Look for something in the pic that you know the size. Like the Cinder blocks on the wall. Your pic-chop is what I would guess to be about a 6 inch chop.
    If you start over and chop it maybe a half inch, save pic, another half inch, save pic (new name of course), repeat until you reach TOO far. Then view them in a slide show. It would help you find just how much chop YOU like.
  16. dudley32
    dudley32
    I think that's a 39 standard...???
  17. Boones
    Boones
    from Kent, Wa
    No chop and leave it low like it is now...
  18. DirtyWoody28
    DirtyWoody28
    since i'm using it for hauling I am going to put my 283 w/ a 5 speed and a Ford 8" so I can run 35 wires on it, I'm keeping the front end but changing the hub/drums to 48s.
  19. DirtyWoody28
    DirtyWoody28
    it doesn't have juice brakes, and the ***le says 37. The 39 standard had the bird beek hood.
  20. Duece King
    Duece King
    from Temple, TX
    2" Chop but keep the back window stock dimensions
    Sitting in the weeds
    Y-Block w/single 4bbl & T-bird Covers
    Top Loader 4 speed (or T5 if alot of highway travel is planned)
    9" Ford Rear with big brakes from a wagon.
    Parallel Leafs in the rear since you plan to tow with it.
  21. DirtyWoody28
    DirtyWoody28
    I should have made a new thread for the actual build, I have already decided on the drivetrain and not to chop it.!!!!!!!!!!!!!!!!!!11
  22. McDeuce
    McDeuce
    from Wisconsin
    Love it .. good luck !
