hurst motor plate and mechanical pump
Discussion in 'The Hokey Ass Message Board' started by mufflerman, Nov 30, 2009.
  1. mufflerman
    mufflerman
    has any body had any luck in putting a mechanical fuel pump on a sbc with a hurst front motor plate? without mods to the plate? if so, what was the pump for?
  2. Greezy
    Greezy
    Never seen it done without modifying the frame mount.
  3. Deuce Roadster
    Deuce Roadster
    I used a set of 4 " SPACERS " that went in between the plate and the block.
    I trimmed the cross member ... My engine was a 56/57 block ( so NO side mounts ). A better way is to fabricate side motor mounts IF your block has the OEM mounting points for side mounts.
  4. scrape
    scrape
    you have to use spacers between the engine block and hurst motor mount....
  5. nutajunka
    nutajunka
    Also the old style carter fuel pumps had screws holding the bottom on and you could move your inlet and outlet to suit your need's......;)
  6. 32 Barn Car
    32 Barn Car
    from Oregon
    The early original kits came with spacers that went between the mount and block . I made mine that allows me to use a stock type mechanical fuel pump in my '32...........Z
    Countn'Carbs and Blues4U like this.
  7. the rookie
    the rookie
    from spring
    i was wondering the same thing. im using a 91 model block with a hurst style mount.
    zdiddy how wide are your spacers they look pretty big
  8. Deuce Roadster
    Deuce Roadster
    Been many years ago but I remember them being 1 and 1/2 inches long. Just mount the pump and then mock fit the Hurst plate ... measure the difference :) :D :rolleyes:
  9. BigChief
    BigChief
  10. solid
    solid
    that's what i did...
  11. mufflerman
    mufflerman
    i'm running a sbc 400. big balancer. can't space the motor plate to much. i have a 1/2" spacer now. i think the summit pump is the way to go. thanks for the info, guys.
  12. the rookie
    the rookie
    from spring
    so would grinding or notching the hurst motor plat be a bad idea?
  13. NoRust
    NoRust
    From Speedway Motors, Part # 91602046, (new) fuel pump can be disassembled to index the inlet/outlet area. Plus the rated output PSI is 6. Edelbrock carbs need 6 PSI, while Holley carbs need 7 PSI. I have seen this fuel pump to work correctly with either of these 4 barrel carbs, thus without the need to install a fuel pressure regulator. I am utilizing a Hurst front mount also.
  14. Jmountainjr
    Jmountainjr
    The original spacers were just a piece of flat bar, about 3/8" thick. They were installed vertical and each one had two holes for the mount bolts. Doesn't take much to clear stock size pumps. So you can easily make whatever thickness you need.
  15. el Scotto
    el Scotto
    from Tracy, CA
    I spaced out the mount on my Mercuchevrofordalet and works fine. Used one the Corvette style Carter fuel pumps you can point the outlets any direction you want.
    Sorry for the crummy picture, I was doing something else.
    kidcampbell71 likes this.
