I recently bought a 58-62 block Chevy 235 that hasn't run in a few years. When I pulled the side cover, I noticed that there were 3 U shaped clips just lying next to the push rods. Supposedly, the engine ran great when it was pulled 3 years ago. What would cause the lifter to rise up so high that it would knock out 3 of the clips? I am hesitant to so much as turn the engine over until I know what is causing this. Thanks
I asked someone about this and they said that this happens occasionally in engines with hydraulic lifters, and that just putting the clips back in place should be all I need. Is there any truth to this? Either way, I will still inspect the lifters before I do anything else.
