cadillac 429 to 350
Discussion in 'The Hokey Ass Message Board' started by desoto-S15, Dec 16, 2009.
  1. desoto-S15
    desoto-S15
    Does any body know if a 350 will bolt up to '64 cadillac 429 mounts?. I didn't want to do it but parts and gas an this big ******* are breaking my wallet
  2. 53sled
    53sled
    from KCMO
    No, and no. you'd be better to get a overdrive for a BOP pattern car, a 200-r4 should be easy to find. I picked up a cheap 4 banger truck for a daily. 25 mpg and $1000 later.
  3. desoto-S15
    desoto-S15
    Damn that's ****s. A friend of mine said it might. I bought this as a running car to cruse wile I'm working on my other project. Wasn't ready for another one
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The small (if any) gas mileage increase wouldn't be worth the labor of such an engine swap anyway.
  5. carcrazyjohn
    carcrazyjohn
    from trevose pa
    You could just buy an adapter plate and put a 2 barrel on it.Sad but true.......
  6. 53sled
    53sled
    from KCMO
    think how hard 350 ci has to work to haul 5000 lbs of detroit steel, vs a torquey 429 ci. There is a reason Caddy put big motors in before everyone else. An overdrive will pay for itself if you can gear it to drive at max vacuum at part throttle, but that costs alot of gas money up front.
  7. HEATHEN
    HEATHEN
    from SIDNEY, NY
    That'll get you nothing. It's already running on the primary barrels of an AFB, which are probably smaller than the barrels of the two barrel would be. Just remove the secondary throttle linkage if you can't trust yourself to keep your foot out of them.
  8. zman
    zman
    from Garner, NC
    Yep, a properly tuned 4 barrel will get just as good of mileage as a 2 barrel. Sometimes better if you can keep your foot under control.
  9. 73RR
    73RR
    If you intend to keep driving the car then you need the low speed torque that the Cad has and the shiverlay does not....
    Do a proper tune-up and drive like grand dad.
  10. Deyomatic
    Deyomatic
    from CT
    Just to back these guys up, I had a 350 powered '73 Bel Air forever. On the Rochester 2bbl it would get 14.5 on the highway. Swapped intakes (stock iron 2bbl for stock iron 4bbl) and threw on a 600 CFM Holley 4160, and an HEI dizzy, and mileage went up to 17 on the highway!
  11. CheapCat
    CheapCat
    from Illinois
    A Q jet will do better than a 2 barrel carb. The primary's are smaller and set up right will give good gas mileage. I have set them up on 472 Cadillac's to get 20 - 21 mpg on the highway and 16 city which is not bad given the size car.
  12. brocluno
    brocluno
    I'd be looking at the tune-up REAL Careful. I bet the advance isn't optimized? Check and recuve the dizzy and run as much advance as you can.
    Wonder how beat the timing chain is? What's the compression like? Run thinner oils in all including the rear end. Get some P Metric tires and run them at 36 PSI or better.
    Get a 200R4 in nice shape and use that overdrive.
    Get a vacuum gage and drive with it.
  13. ratcaddy65
    ratcaddy65
    When i got my 64 it had a 350 in it and it was so underpowered so im putting a 500 in it
