Rear end questions?
Discussion in 'The Hokey Ass Message Board' started by Chuck Fish, Nov 22, 2004.
  1. Chuck Fish
    Chuck Fish
    I just bought an Auburn posi unit with the spacer for my 10 bolt chevy rear ( out of a 84 Monte Carlo )Is it safe to say that I can swap the old carrier out for the new one without having to reshim and set the gear spacing. I figure if I don't change the ratio it should be a bolt-in.
    Chuck Fish
  2. Blownolds
    Blownolds
    from So Cal
    It's safe to say that you will still have to re-set the lateral adjustment, and therefore you will have to paint the gear teeth up and check the mesh again.
  3. willowbilly3
    willowbilly3
    from Sturgis
    I have to wonder why put money into one of those weeny metric rear ends.
  4. Chuck Fish
    Chuck Fish
    That's not the answer I was lookin for ...but I'm sure you are right. Thanks for the input. [​IMG]
    And Willowbilly...It ain't a monster motor so I don't need a monster rear and when I'm done I'll have less than $250.00 in the whole deal and a rear end that will last me many miles. [​IMG]
    Chuck Fish
  5. Brad54
    Brad54
    from Atl Ga
    Yeah, you've gotta re-set the rear end. The machining on the new case might not match, exactly, the machining on the old carrier. All it has to be off is a few thousandths.
    -Brad
