Cadillac 390 Oil issue. Need some help
Discussion in 'The Hokey Ass Message Board' started by suicidal-element, Dec 17, 2009.
  1. suicidal-element
    suicidal-element
    from Auburn, CA
    I am looking at buying a 62 Caddi. The only thing is, oil is blowing out of the vent onto the engine (not a ton, but some). What would cause this? Is this a major issued or minor?? Please let me know. Thanks!!! See picture for details.
  2. Caddy-O
    Caddy-O
    Cracked rings ?
  3. blackrat40
    blackrat40
    If it's blowing out the breather tube,or oil fill tube, it could be "blow-by" from
    worn piston rings allowing combustion gases to to pass into the crankcase and
    out the breather. This may not be the problem, just a possibility.
    Do you get any blue/white smoke out the exhaust(indicating maybe worn rings
    or valve guides)?
  4. suicidal-element
    suicidal-element
    from Auburn, CA
    SOme white smoke for sure. How bad of an issue is this?? I am not educated in engines at all.
  5. blackrat40
    blackrat40
    With only the info given, some people would say that the engine may need a rebuild.
    If it is pretty high mileage that might be the case.
    However, a engine that has worn rings may serve you for 20,000 more miles.
    A compression test at a local garage will reveal a lot about the engines condition.
    You can also do that yourself. It's not beyond the amateur mechanic to do it.
  6. suicidal-element
    suicidal-element
    from Auburn, CA
    Thats what I needed to know. Thanks.
