Projects 1930 sedan project pics
Discussion in 'The Hokey Ass Message Board' started by jtille, Feb 21, 2009.
  1. 29nash
    29nash
    from colorado
    Looks great to me too. :D
  2. jtille
    jtille
    Not my car just a pic notice the front end
  3. HotRodBen1987
    HotRodBen1987
    Just caught this thread and gotta give it to ya nice work. Not exaclty sold on the front end setup looks like you aint got much travel goin up without hitting the steering arm or axle but hopefully it'll work for ya. Good luck
  4. Killer
    Killer
    its good to see Tman still can't give good info...
    it'll work just like a "normal" suicide mount.
  5. heatmiser
    heatmiser
    from mia
    true, and true.
    except that in this case, a flat tire or bottoming suspension can set the low frame horns into pole vault/ jousting mode... it could get ugly...
  6. VAPHEAD
    VAPHEAD
    where is your radiator going to sit?
  7. jtille
    jtille
    The radiator will sit behind the axle and in front of the spring mount
  8. nick28
    nick28
    from Kentucky
    Looking good, love the stance!
  9. HotRod33
    HotRod33
    Interesting build....
  10. jtille
    jtille
    Thanks for the nice words. I still need to notch the frame for the steering and the axle.
  11. Looking forward to your next update with pics, thanks !
    / primerkid
  12. jtille
    jtille
    Thank you
  13. jtille
    jtille
    Drilled and sleeved the spring mount this evening.....****py phone pics
  14. A 29 sedan followed me home to...Desoto hemi to... strange....
  15. kaboom
    kaboom
    from STL, Mo
    Did you really scuff up the new paint?
  16. jtille
    jtille
    Yeah man scuffed her right on up!!
  17. WILTBILT
    WILTBILT
    from VIRGINIA
    Keep the pics coming
  18. jtille
    jtille
    Got some parts in early last week the buckets and today the lens
  19. jtille
    jtille
    Got any pics of it?
  20. captainjunk#2
    captainjunk#2
    i like the build coming along nice i like the triumph in the picute above also
  21. HOTRODVAN
    HOTRODVAN
    I haven't seen many pics in here, so here's mine. It was a 4 door, chopped 3 1/2 inches, filled roof, back door, it'll be a flat head with a 5-speed, dropped axle, 8" rear, full fendered, '32 grille shell and gas tank in rear. I hope to drive it this year. Wish me luck.:D
  22. twinkey
    twinkey
    LOOKIN GOOD! the wide 5's are *****in. how much did you chop it?
  23. jtille
    jtille
    Thanks man the chop is 6 inches
  24. jtille
    jtille
    Thanks for the kind words people!!!
  25. jake85
    jake85
    nice work so far
  26. Just Gary
    Just Gary
    Any updates???
    BTW, I was looking thru some old magazines and noticed that Pinkee's Rod Shop used the same front spring arrangement (suicide bracket underneath the leaf spring stack) on "Loaded", their '28 RPU.
    The spring doesn't know (or care) if it's bolted above or below the bracket.
    No pictures, but here's a link:
    http://pinkeesrodshop.com/Loaded_Build_Book-s17.aspx?i=6
  27. scootermcrad
    scootermcrad
    Nice build!
    I used a similar setup for my front spring and I have to tell you, you seriously have to make sure you get the frame right the first time. You can't shim it as easily to adjust the ride height... unless you want it lower. Mine puts the crossmember SUPER low. It's almost below the scrub line. It makes me nervous for sure. I'll never build a front suspension arrangement like this again without making a way to adjust it easier.
  28. I've heard this pole vailt theory relative to scrub line many times.
    My opinion is that the vehicle would only pole vault if the frame
    dug into dirt surface or very uneven pavement. More likely scenario is
    it will simply skid-s****e to a not very controled stop. That was from
    personal experience!
    jtille;
    excelent craftsmanship and sound engineering. Enjoying the build.
    Buffalo Bill.
  29. Go to my albums to see my A,not alot of pics but more to come.
  30. jtille
    jtille
    No updates no more OT at work.....I will check out the link thanks
