Projects It's as bad as it looks
Discussion in 'Traditional Hot Rods' started by 1/2done, Dec 19, 2009.
  1. 1/2done
    1/2done
    from Ohio
    I had to sell my g***er to keep a roof over my head, I didn't want to but sometimes you have to act like a grown up. I really wanted a metal working project to work on, I have 2 4x8's of 20ga so I can work without spending money for a while. So some extra parts and some trading later and I'm the proud(?) owner of a '40 Ford coupe that was in a garage that burned to the ground.
    I've never used a shrinking disc before, but I think this may be a good time to learn. The rest of the body parts are from a different car so they only need rust repair. Plans are to get all the metal work done and then decide a direction, I'm leaning toward a Lake style coupe.
  2. sawbuck
    sawbuck
    from 06492 ct
    wow...gonna save it...cool..and good luck....keep us posted.
  3. captainjunk#2
    captainjunk#2
    i will follow this thread the metal work alone will be worth the veiw time good luck with it
    Outback and Dave Downs like this.
  4. Mazooma1
    Mazooma1
    good for you...you save some neat stuff and exercise your skills at the same time...:)
  5. buckeye_01
    buckeye_01
    You are certainly ambitious. Good luck.
  6. AstroZombie
    AstroZombie
    from Marina, CA
    Nothing wrong with doing what you have to do. Sad to hear you had to sell your g***er, but in the end this may be for the better. You'll get to learn more metalwork, and also get the thrill of the next build. Good luck, doesn't look like too bad of a start.
    chryslerfan55 and badgascoupe like this.
  7. Jim Sideways
    Jim Sideways
    from Ohio
    I like 40 Fords. Good luck, keep us posted...
  8. xlr8
    xlr8
    from Idaho
    Not to hijack the thread, but what kind of luck do you generally have working metal that has been burned? I saw a pretty nice old chevy coupe body once years ago that I asked the guy about buying and he said it had been through a fire and even tho it looked pretty good it was ruined and he wouldn't sell it to anybody. He said he had tried to do some work on it and it was hard and brittle and the metal wouldn't work anymore.
  9. pasadenahotrod
    pasadenahotrod
    from Texas
    Years ago a friend bought a 39 Chevy coupe which had been in a garage fire some 30 years before that. The guy repainted the car several times and the paint just sloughed off every time after a few weeks or months. We parted it out.
  10. Looks like you got a good start there. Good Luck! Mikey
  11. 1/2done
    1/2done
    from Ohio
    If it ends up unworkable I'll build a "survivor" dirt car and paint it with house paint.:D
    chryslerfan55, Jet96, 283john and 2 others like this.
  12. One other thing, use some of that "metal etching primer" first, so the paint wont come off.. Mikey
  13. RichG
    RichG
  14. ironandsteele
    ironandsteele
    picked a good one to save.
    good luck with it.
  15. Stevie Nash
    Stevie Nash
    I hope you have some bodacious metal working skills....:cool:
  16. Hyway Hauler
    Hyway Hauler
    Jesus H. Christ! you have your work cut out buddy...but I've seen worse one turn out great!
  17. 61 chevy
    61 chevy
    make a good rat rod
  18. I don't care what sort of metal it is- it will take paint if you have it sandblasted clean and then spray it with epoxy or self-etching primer.
    I'd straighten up the overall body shell enough to have consistent gaps for doors, deck lid, etc. I'd even test fit some gl*** just out of curiosity to see exactly how bad it is. Will be interesting.
    chryslerfan55 and kidcampbell71 like this.
  19. 1/2done
    1/2done
    from Ohio
    I'll crush it first.
    57JoeFoMoPar, e z i, chlsnk and 11 others like this.
  20. The37Kid
    The37Kid
    Good luck, if it was burned, that is one thing, if the fire dept hosed it down that is another. Getting it to stop rusting will be another problem. Not trying to kill your ambition, just p***ing along things to think about.
    chryslerfan55 and lothiandon1940 like this.
  21. rat seeker
    rat seeker
  22. 1/2done
    1/2done
    from Ohio
    I'm going to hose the inside down with rust converter, the outside I'm thinking about scrubbing it with muriatic acid and a scotch brite.
  23. Ghost28
    Ghost28
    Aww hell being a grown up was the first step. This will be easy, and fun for ya. And prolly ease the pain of selling your g***er...John
    I know how right your choice was.
  24. onedge
    onedge
    1/2 done I like your state of mind. Good luck.
  25. mart3406
    mart3406
    from Canada
    I've see guys start with lots worse and end up with some pretty incredible cars. It'll take time and bunch of work, but it's savable. Good luck.
    Mart3406
  26. solid
    solid
    Look good nose high, with some americans, or halibrands.you need a new g***er anyways...
    osage orange likes this.
  27. Flatheadguy
    Flatheadguy
    Don't let anything or anyone talk you into a funk. I suppose some would just buy a fibergl*** whatever body. You can save it. In my many decades of rodding life I have found that 80% of doing it is having the stones to start. Much worse has been pulled back from the dead. Please, keep us updated.
    fatassbuick and chryslerfan55 like this.
  28. Strange Agent
    Strange Agent
    You can do it. Keep on it.
    Bring it back to life.
  29. fleetside66
    fleetside66
    Just curious, seriously, how does burning off paint/bondo & then exposing the metal to water any different than stripping the paint (in any fashion) & having it flash rust. I stripped stuff with vinegar, for example, & almost immediately had to fight a light coat of oxidation. How does this compare to any sort of surface rust situation? Is there a different sort of problem with this particular car (if it was indeed hosed down)?
  30. PeteFromTexas
    PeteFromTexas
    Good answer
