WARNING: Do not touch-up your motor with a die grinder
Discussion in 'The Hokey Ass Message Board' started by 63dan63, Dec 21, 2009.
  1. 63dan63
    63dan63
    Once you start ... there is no logical place to stop.
    It's addictive! You will find yourself spending 40 to 50 unplanned hours on your project.
    Please, take my advise. DON'T START.
  2. 067chevy
    067chevy
  3. Roothawg
    Roothawg
    Yep, I have the same sickness.
  4. onedge
    onedge
    what is it? i dont recognize...
  5. dieselc
    dieselc
    from ohio
  6. czuch
    czuch
    from vail az
    I was expecting only the worst.
    Atsa nice, vuuuuurrry nice.
  7. sixpac
    sixpac
    from Courtenay
    back to the old grind
  8. snapper
    snapper
    from PNW
    Looks great.............Then someone comes along and decides that they need it mores than you do.
  9. Left Turn
    Left Turn
    from Omaha, NE
    I think Poncho... not sure.
  10. ironandsteele
    ironandsteele
    that is a crazy amount of work..
  11. menacekustoms
    menacekustoms
    Dang man. I joked about that in another thread. I don't have the patience for that, but yours looks great.
  12. Von Rigg Fink
    Von Rigg Fink
    from Garage
    thanks for the heads up!
  13. swimeasy
    swimeasy
    People as persistant as you, I don't understand, but that looks great in an unbelievable sort of way. (please take this as a complement).
  14. If you're bored and want to do something that actually serves a purpose drill & tap the missing exhaust manifold holes in the heads. Leaving out the very end holes worked ok with stock engines & stock cast iron manifolds but you'll have a hell of a time getting headers to seal. Just a little advice from a guy who's played with a Pontiac once or twice.. You can use the gasket to go by. They always put the holes there on the older engines. The smoothing looks good.
  15. Dead Pan
    Dead Pan
    damn thats purty
  16. langy
    langy
    Looks super nice, and yes i share your pain as i've done the same twice.
  17. touchdowntodd
    touchdowntodd
    very, very freakin clean
  18. Randy in Oklahoma
    Randy in Oklahoma
    from Oklahoma
    How were you able to stop at 50 hours? I am still grinding away!!
  19. and some people claim o.c.d. is a bad thing
    looks awesome!
  20. Yep . . . been there a couple times, just can't help myself. Did this 3 years ago, won't be starting the motor until next spring. My projects are all "vintage" - at least they are once I get them to completion :eek:
  21. Rickybop
    Rickybop
    You aint kiddin' 63dan63!!! You can't stop after starting! How in the heck are you gonna stop, after you've got one small smooth area! Did this on my '66 Nailhead 425. Had the engine dis***embled, thought to myself...Well, we'll give this a try. Ater I had smoothed a small area, I realized how much work I was in for, but again, how ya gonna stop? You've got a casting with a fairly uniform surface-texture, but with an isolated area that you've made smooth. Had to continue. Did the whole block and heads. Holy cow, what a lot of work!...and time! Not that I really regret it. I tend to enjoy detailing. I do like 'em smooth. To me, those rough castings just don't look as nice as the rest of the car, no matter how nice you paint 'em. Your heads look real nice. Now get busy on the block! HA! - Rick
  22. holeshot
    holeshot
    from Waxahachie
    DAN the man...brother it was worth every minute, now get that other head done. and i'am thinking thats an old's or caddy mill. RIGHT?...your new admirer...POP.
  23. Pontiac all day long. And judging by the exhaust side of the heads not having the bolt holes drilled & tapped on the very end ports I'm guessing it's from the 70s-mid 80s
  24. 19Fordy
    19Fordy
    Wonder if that will decrease engine's ability to rapidly dissapate heat.
  25. Rickybop
    Rickybop
    I don't believe so. If there's a difference, I'd guess that it's miniscule.
  26. Rusty
    Rusty
    smooth motors rule! stopped by and seen ur ch***is last week, almost a roller
  27. Scarebird
    Scarebird
    Alliance Vendor
    from Moita, PT
    no, but it will be louder - the rough, crenelated surface aids in quieting the motor.
  28. wizzard23
    wizzard23
    Been there, Done that, forgot why1
  29. wizzard23
    wizzard23
    Been there, Done that, Forgot why!
