Question about body lines
Discussion in 'The Hokey Ass Message Board' started by Big Wave Dave, Dec 21, 2009.
  1. Can someone tell me the difference in a 28-29 model a coupe and a 30-31 coupe? Have not been able to see them side by side and not sure if my old mind is playing tricks on me but looks like from some pics. the 28-29 slopes off quicker in the back behind the rear window and the 30-31 goes back a little more before it curves down.
  2. 28-29 has a distinctive coach line at the "A" pillar. Looks a lot like a 26-27 Model T coupe or sedan. The 30-31 has a distinctive cowl band. Lots of other differences. But those are good for quick spotting.
  3. slddnmatt
    slddnmatt
    just look at the gas tank, 28-9 has a nice swoop to it plus the body lines on the side are a single flat and 30-31 have a double bump if that makes sense
  4. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    First is a 1928-'29 Ford, look at the cowl (the section to the front of the door) the gas tank is much deeper and there really isn't much of a defined body line. The cowl on the '28-'29 is also a bit narrower than the rest of the body:
    The second picture is a 1930-'31 Ford. Look at the cowls, the body lines on the doors, etc...
  5. Rickybop
    Rickybop
    Unless it's been welded and smoothed, the '28/'29 has a distinctive seam on the cowl side near the top. The cowl itself swoops inward from back to front or from hinge-pillar to firewall. There are some other differences. Hear...see for yourself. Black one on the left is a '29. Light green one on the right is a '30/'31. The deck or rumble lids are quite similar, in that they both curve down slightly from behind the driver, then straighten out then do the big curve down. A '30/'31 is also just a little deeper from doortop to floor.
  6. cretin
    cretin
    Well since you asked about the rear end of coupes and everyone is talking about cowls and showing you roadsters maybe this pic will help you out better. Here is a side shot of a 28/29 coupe and a 30/31 coupe right next to each other. Compare and contrast.
  7. 19Fordy
    19Fordy
    I think one has dooredges that overlap the body while the other has door edges that are flush with the body.
  8. millersgarage
    millersgarage
    28-29 have flat line/features at the belt, 30-31 are rounded. 28-29 do not have a body line along the bottom and around the rear wheel openings like the 30-31 does. 30-31 door window openings are slightly curved on the upper, the 28-29 are flat. 28-29 have a flat sunvisor and sit slightly below the roof line, the 30-31 has a visor with a feature line, and is flush to the roof.
    but the cowl is the biggest ataglance difference
  9. millersgarage
    millersgarage
    looking at ******'s photo, I see what you are talking about the curve of the qtrs, I never noticed that before.
  10. pasadenahotrod
    pasadenahotrod
    from Texas
    All the above IS true BUT the 28-29 Fordor And Town Sedans and Cabriolets have a cowl similar to the 30-31 which can confuse things. They have a 3 piece firewall whereas the other body styles have a 2 piece firewall.
    On all 28-29 bodies, the top portion of the firewall is the wall of the fuel tank.
    On 30-31 bodies, the firewall is 1 piece is bulged forward and the tank wall is hidden behind it.
    28-29 Cars and Pickups have screw on radiator and gas caps which are the same size but the fuel cap is vented.
    30-31 Cars and Pickups have conventional 2-ear mounting for the caps and the gas cap is larger than the radiator cap.
  11. Reds 29
    Reds 29
    On the coupes, the 28-29 doors overlap front and back, 30-31 doors flush fit front, overlap at back. The tops are quite different but difficult to tell on the two chopped ones in ******'s picture. The curvature of the top at the back is different, and the way the cloth roof attaches is different. The 28-29 top material comes down to the drip rail and the 30-31 just fills the hole. The curve of the trunk is slightly different as seen in the picture but the deck lids are basically the same, except for the way the rumble lid latch attaches to the decklid. Also the quarter windows are slightly different shapes.
    Red
  12. Awsome response, never really noticed all the differences. Thanks for all the info. you have all helped me out.
    dave
  13. Rooney00
    Rooney00
    13 posts to stammer about what two pictures can answer instantly. Really?
  14. cretin
    cretin
    Seems to me it only took 6 posts and 1 picture. ;)
  15. 55 dude
    55 dude
    what years seem to be the more sought after?
  16. KUZTOM
    KUZTOM
    To true, I got a cowl,always thought it was a 30, but its a 28-29 offa town sedan.
    In NZ ,we didnt get many 31's due to the depression ,so im told.
  17. david buick
    david buick
    from Topanga
    So,
    can you put a 30-31 cowl to a 28-29 without much trouble?
    thanks
  18. hemi
    hemi
    Damn that thing is chopped! Wow.
  19. #### 36-24-36 !!! Nuff SAID >>>>.
