Hot Rods My full race flatty 6. First fire video.
Discussion in 'The Hokey Ass Message Board' started by Dynaflash_8, Dec 21, 2009.
  1. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Here it is, first fire of my .030 over full race flatty. Still needs some tuning, but runs alright.
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/smyHCN2DNC8&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/smyHCN2DNC8&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
  2. PhilJohnson
    PhilJohnson
  3. daliant
    daliant
    :D thats like music to my ears!
  4. Scott F.
    Scott F.
    That thing sounds great! Wish mine had half of what that things got.
    What are the details of the engine build?
    Scott
  5. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    its a 54 Plymouth 230 flathead 6. .030 over, line bored and decked. Head was milled down .040 thousands. Its been ported smoothed. Intake is an offy dual carb modified to fit the ford carbs. the cam is a re-ground stocker, with .550 of lift and 236 degrees of duration. it has forged aluminum pistons, and a balaced rotating ***embley. ****** is a powerflight that has been rebuilt, and tightened up 10%
  6. Retro Jim
    Retro Jim
    Now that is one bad *** flat 6 !
    What size cam you got in that engine ?
    RetroJim
  7. Hitchhiker
    Hitchhiker
  8. plym_46
    plym_46
    from central NY
    Once you get settled down, sinc the carbs up with tool so the throttle plates are opening same time same distance. then you can deal with the idle. Don;t forget to retorque the head following the correct sequence. And remember when you re adjust you valves, a bit loose is preferable. then put a vacuum gauge on it should be in the 16 to 18 inch level at a slow idle 450 to 500. Once you get a decent idle set the timing by using the vac*** gauge turn the dizzy till you get the highest steady reading. then when you check it with the light it will probably 4 to 6 degrees BTDC which is where ti needs to be with modern "gas".
    Sounds pretty good for the first light off.
    I am real happy with my 56 dual carbed flatty. I took 40 off the head and 10 off the block, rest is stock except for 30 over. One of my plymouth friends has a 54 with a stock 230 and the power glide and he really likes the way it drives.
  9. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Thanks for all the info. That startup was actually using only one carb, because they both have 65 mains, which is enough to run the motor on one. Im trying to find some 47 mains, but the local speed shop only has em to 55.
    As for the idle, thats about how its gonna idle. The cam has 110 degree lobe seperation, 236 degrees of duration, and .550 of lift. Now i just gotta finish up the frame and drive it!
  10. Hitchhiker
    Hitchhiker
    shotgun!
  11. E-racer
    E-racer
    from STL
    That sounds pretty damn radical! Where did you get/have the cam done?
  12. E-racer
    E-racer
    from STL
    btw, you're making my 230 .030 over, 2 barrel carb, Langdon headers, .050 shaved head, 260 degree .410 lift motor that has yet to fire seem kinda lame. ;)
  13. ...you gotta look at his cam specs, with 236 at 50thou you can forget about 500rpm idle and vacuum...uh...what vacuum...maybe 6 to 8 if your lucky....
    Sounds good though...;)
  14. stude_trucks
    stude_trucks
    Did you put a crank balancer on it?
  15. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Thanks man. Delta camshaft in Tacoma WA had the grind. $89 dollars to regrind the cam :p
    Hahaha. it'll sound just as wicked, trust me! What kinda pistons are you using? Mine came from egge machine.
    They came with a harmonic balencer
  16. Hitchhiker
    Hitchhiker
    nice i'm running a delta in my 1979 460. it's cam grind #214 nothing wild(have to grab the cam card for specs) but way more cam then the stock retarded 10 degrees emssions era stocker grind. Great customer service. when I called them and told them what I was building, parts involved, ect. and what I was shooting for hp wise. this is what they recommended and I have been really happy with it.
  17. Now thats what I'm talking about. Way cool, and it ain't a sbc. I love it.
  18. johnny bondo
    johnny bondo
    from illinois
    damn dude. that thing just sounds like its about to murder some people. kind of like a 50 cal machine gun at full blast lol i like it.
  19. steeljunkieII
    steeljunkieII
    Now that was cool thank you
  20. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    thank you! When i first tried to get it running, i didnt have the transmission bolted all the way down. Big mistake. Soon as it caught, the entire motor was shaking back and forth 10 inches, and i couldnt hold onto the throttle.
  21. Don Coatney
    Don Coatney
    Sounds good. What is your cam overlap? Your valve lift (.550") is a lot. What valve springs are you using. It is a good practice when first starting a reground cam to run the RPM's up to 2,000-2,500 and hold them there for 20 minutes of so.
    I am running dual Carter B&B,s on my Desoto flathead 6. If I attempt to run my engine with only one carburetor it will not idle much the same as yours. However my cam is not as lumpy as yours is.
    I have found that even with many modifcations my engine is very dependable. I have driven it close to 30,000 miles with no problems. These pictures were taken in Detroit a couple years back. The guy on my right is 46 plym.
  22. LabRat
    LabRat
    Got to admit , when a 19 yr old kid tells me he has a full race motor , I'm goin to be skeptical ....:D
    Mind you it sounds the goods ..... should be smoother with both carb's .
    Neat !:)
  23. onlychevrolets
    onlychevrolets
    that sounds to good ......
  24. TomT
    TomT
    Man that sounds wicked - my hat's off to you!!
  25. dragass
    dragass
    To be honest with you I never really heard to many flathead 6"s run but GODDAMMIT! that thing sounds evel. Nice job man.
  26. That mill sounds great, congrats. The '55 Dodge 230 in my '39 is punched .060, block decked, Fenton head, Edmunds intake w/2 1bbl Carters, Langdon headers, and an Edgy cam. I have a Mallory dual point dizzy that will go in shortly. It's very tame compared to yours.
  27. greaser
    greaser
    That will definately turn some heads when you coast into that parking spot at the local cruise night....WOW!
  28. Toby Denham
    Toby Denham
    from Georgia
    Man, I enjoyed that! Thanks.
  29. Rich Wright
    Rich Wright
    I like it. Sounds strong and should make an impression at the stop light:)
