help identifying this bench seat
Discussion in 'The Hokey Ass Message Board' started by vtkid, Dec 26, 2009.
  1. vtkid
    vtkid
    from Ohio
    This seat came with the truck('57 3100). What's it from??
    Your input is greatly appreciated!!
    VT kid
  2. Rogga
    Rogga
    100% sure that it comes from a car or a truck....or something else................:rolleyes::D
  3. squirrel
    brackets look sorta like 58-64 chevy full size car
  4. markjenks
    markjenks
    I'd bet the same as Squirrel. Looks like a GM to me. With the Vinyl on it, I would guess it'd be a truck. Not many cars had 100% vinyl on them like that.
  5. If you pull it out, there is usually a metal tag attached to the seat bottom springs. most split benches were 2 dr cars. It does not look Ford, so GM or Mopar is what I'd go with too.
    Measure the seat backs, the hardtop ones are shorter than sedans.
  6. squirrel
    the full vinyl is just a cover, you can see some of the original upholstery where the dark cover is torn
  7. hotrod-Linkin
    hotrod-Linkin
    1959 belair is as close as i can get that seat trim.
  8. Rs2
    Rs2
    I don't think that the cylinder head is stock for that seat either...
  9. HotRod-Linkin is as close as I could guess, also. The track tells me its definitely GM car, late 50's-early 60's.
  10. squirrel
    The head could be from a 58-62 chevy full size car as well.
