early 60's 3 speed problem
Discussion in 'The Hokey Ass Message Board' started by Kilgore, Dec 26, 2009.
  1. Kilgore
    Kilgore
    from Earth
    I have a 63 Bel Air with a manual 3 speed on the column. In the wintertime it gets difficult to cross the "H" when going between reverse/first to second/third and back. During the summer the car shifts fine. The difficulty definitely has something to do with the weather. Is this a problem with the fluid in the ******? How can I make it travel across easier?
    btw: I live in Kansas, so it never drops below -5 degrees if that helps.
  2. squirrel
    Yup, probably a steering column problem, I'd take the column apart and clean, lube and adjust the mechanism. Although most guys seem to be scared of taking columns apart. It would help to have the shop manual.
  3. Dennis D
    Dennis D
    When ypu pull or push the shift lever you are moving a tube inside the column. Needs to be taken apart and cleaned and lubed like squirrel said. Probably just gumed up from years of use. Dennis
  4. Might be able to use some "Jesus in the Can" on that column?
  5. squirrel
    The sliding parts are way inside, not where you can squirt them.
  6. brocluno
    brocluno
    Best oil for manuals is Red Line MTL. It's light and makes shifting so smoooth. No reports or any failures running big power - excellent lube. BMW guys been doing it for years to get their sticks to shift in the winter. Once you try it, you will not go back :)
  7. R Pope
    R Pope
    Your problem is not in the transmission, its the shifter. Spray some penetrating oil in every opening you can find around the levers and in the column where the stick comes out of it.
  8. Move to Arizona or Florida
    just my 3.5 cents
    ha ha ha
  9. what I use to do was Warm up the Car real good!
    before I wood Drive it
    or Change the ****** Fluid to a Lighter Weight for Winter
    and back in the Summmer
    Just my 3.5 cents
