Home made inline intakes, let's see 'em!!
Discussion in 'The Hokey Ass Message Board' started by Left Turn, Dec 31, 2009.
  1. Left Turn
    Left Turn
    from Omaha, NE
    I want to build an intake for my 223 and just want some ideas... I don't car what kind of engine your runnin' as long as all the cylinders are in a row... Just need ideas...
    So show me your home made intakes!!
    Thanks!
  2. kwoodyh
    kwoodyh
    I've never seen one that worked worth a hoot! Honest Charlie (I think) had some kits to add additional carbs once upon a time. I'd go vintage Offy or Clifford and use their R&D dollars. If you already have a TIG and a tube bender you might save some cash?
  3. Left Turn
    Left Turn
    from Omaha, NE
    I don't want an Offy or Clifford, everbody has 'em... Plus they'd look out of place on the rest of project... I was thinking about making a log type intake (similar to a U-Fab or something)... But I've got 3 engines to play with which means 3 intakes... So I had an idea about wacking all of them up into peices welding them back up and having a factory look 2 or 3 carb manifold... I was thinking of doing the same thing with the exhaust manifolds by making a split manifold... If wanted to I could go crazy with a tig and a tube bender too but that doesn't fit into my plan either...
    Anyways, I'd still like to see pics!
    duecesteve likes this.
  4. Jethro
    Jethro
    Homemade, but not carbed....EFI
  5. I got this from the "Little Books " social group. Todd
    04-02-2009 05:00 PM
    White Brothers
    With the HAMB Drags coming up, here is one to set the tone for any of you "diehards" that are running an Chevy 6.
    vtx1800 and tractorguy like this.
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    If well constructed, there's no reason that a homemade dual intake for an inline six shouldn't work as well as an Offenhauser/Edelbrock/whatever intake. It's not like there's any real science behind them; any inline six cylinder intake I've ever seen was nothing more than a fixture to bolt more carbs to the engine. Hacking open a dual plane V8 intake and haphazardly welding extra carb mounts to it is another story.
  7. "
    I've never seen one that worked worth a hoot! Honest Charlie (I think) had some kits to add additional carbs once upon a time. I'd go vintage Offy or Clifford and use their R&D dollars. If you already have a TIG and a tube bender you might save some cash? "
    "thspew! cough! hack! spit!" I darn near gagged! I could not live with that thought! I wouldn't trade the fun and experience gained from designing, making and successfully running my own stuff for any amount of money!
    Here is one of mine.
    Don
    57Fury440, X-cpe and AccurateMike like this.
  8. dodgedartgt
    dodgedartgt
    from SW FL
  9. fordcragar
    fordcragar
    from Yakima WA.
  10. johnny bondo
    johnny bondo
    from illinois
    todds old plymouth, kinda looks like **** and armature though.
    AccurateMike likes this.
  11. ^^^ hahahahaha I think it looks fine :)
  12. Here's the one I did for my Iron Duke 4-banger.
  13. Alfster
    Alfster
    I built this one for our 270 GMC. Uses 5 single throat Stromberg carbs. Runs well.
    AccurateMike and duecesteve like this.
  14. Stovebolt
    Stovebolt
    Her's some I found over time on the box of wisdom, with the last one being my Wade Blower manifold setup.
  15. BCCHOPIT
    BCCHOPIT
    here is mine I hope to make a new one out of stainless over winter I need more carbs
  16. moose
    moose
    I resemble that remark...
    That was five years and about twenty manifolds ago. This is what I have on mine now:
    57Fury440 and AccurateMike like this.
  17. teddyp
    teddyp
    found this out in pa. at sled scene east with jimmy (kustom777 now a texan)it was made from a kit from the little pages
  18. Cody Walls
    Cody Walls
    here a intake i made, adapting su carbs to my 292
  19. neverdun
    neverdun
    Alfster, your steering wheel is on the wrong side...be careful!!!!!!!!!!!
    That intake is wild!
  20. Cody Walls
    Cody Walls
    from a nother angle[​IMG]
  21. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    :DHere's mine. Runs great. Not always a fun time to build, but perserverence paid off!
    Dellortos are Throttle bodies now. Scoots down the freeway at 22 mpg in that big Burb!
  22. waldo53
    waldo53
    from ID
    WOW! You guys are super talented. Mine's low-tech and lowbuck, based on the stock manifold.
    I'm running this currently on my 235. Homebuilt using 2" exhaust tubing for the risers, and some 1/4" mudsill plates I found at the local hardware store for the mounting flanges. I cheated a little on the carb location, mounting them a little inboard of the intake runners so I wouldn't have to butcher my firewall.
  23. lakester47
    lakester47
    This is a very simple one I built for The Special. Not nearly as artistic as many of the others that have been posted, but it works.
  24. 29nash
    29nash
    from colorado
    Not homemade, but original single carb intake that I modified to handle three.......
  25. Astrochimp
    Astrochimp
    from NE Mo.
    Suzuki Samurai's are making intakes and using one Harley carb per cylinder.
    Very simple set up and supposed to be easy to tune and cheap.
    I think Google "Samurai + HD sidedraft" should work.
    Replace the air cleaner and it might work for some cars.
  26. Dzus
    Dzus
    Hey 1950ChevySuburban,
    Did you come up with a work around for the 'port robbing' effect of the bathtub ports with your EFI? I was following your progress across a number of boards and never heard if you got it beat.
    I want to play with an IR set up before I kick the bucket. :D
  27. cyclejim
    cyclejim
    there AWSOME CAN ANY HELP ME FOR A EXGUEST ON A MOTORCYCLE . CYCLE JIM
  28. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    UPDATE: Here are a few I've done -
    int3x110.JPG peteint01.jpg sr_048.jpg xflo vlvs02.JPG adv23t044.jpg 243 motor 3.JPG buildup13.jpg int3x109.JPG
  29. Jethro
    Jethro
    Wow , I replied to this 14+ years ago.
    Here's a recent manifold I cast last summer for a GMC 302. 20230928_142200.jpg 20230928_142145.jpg
    INVISIBLEKID, AccurateMike and 302GMC like this.
