New member
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by 1940truck, Dec 25, 2009.
  1. 1940truck
    1940truck
    I am finishing a 67 Camaro - frame off and just 1/2 thru interior. Starting a 1940 Ford P/U. Dipped, stripped and primered for now. Have repro frame rails. Visits to junkyard and scored a mustang/Pinto front. Bought a LT1 from a caprice and ZF 6 speed. Looking for a bed and tailgate near Amarillo Texas
  2. rayford
    rayford
    from calhoun ga
    welcome from ga
  3. THE_DUDE
    THE_DUDE
    Frame off Camaro??? Wow.
  4. ChevyRat
    ChevyRat
  5. ibflyin
    ibflyin
    from Tulsa, OK
    Welcome from Oklahoma!
  6. fieldofcars
    fieldofcars
    Welcome from Missouri.
  7. 440shawn
    440shawn
    Welcome from Illinois
  8. PegLegStrick
    PegLegStrick
    Thought Camaros were unibodys????
    Welcome from South Georgia :D
  9. 1940truck
    1940truck
    PegLegStrick, you are correct, the camaro is a unibody. The 67 camaro was stripped, dipped. The subframe was removed and repaired, damaged front horn. Roof removed, Donor car used for rockers , tail section. Used 2 engine stands for rotation. New floors, Roof from up north. Repro front clip doors and quarter panels. Ford 9 inch rear, M 21 trans, 496 BBC, Holley 1050, roller cam, GM Alum heads, Alum H2O pump , radiator. Putting door glass then finish interior. 22 degrees in my garage. Will have to wait awhile.
    As far as the Ford, I found repro bed in Delores Co, for $799. Will order in Spring. I thought that I would join for help. The Ford was a rolling chassis. The frame is rotted but repairable, just easier to start with new rails. No bed. Had 4 metal fenders though. Sheetmetal repair is done.
  10. ZRODZ
    ZRODZ
    I'm sure it's just a figure of speech.
    Another welcome from Washington.
  11. 1940truck
    1940truck
  12. chilly1
    chilly1
    from Tacoma,Wa
    And yet another Welcome from Washington
  13. 1940truck
    1940truck
  14. 1940truck
    1940truck
    Yes figure of speech
  15. 1940truck
    1940truck
  16. 1940truck
    1940truck
  17. 1940truck
    1940truck
    Another project
  18. 1940truck
    1940truck
  19. 1940truck
    1940truck
    Project #3 of the summer
  20. 1940truck
    1940truck
    Thanks for the warm welcomes. Happy New Year.
